Giriş
Use this guide to replace a worn-out or dead battery in your Logitech MX Keys wireless keyboard.
Lithium-ion batteries have a limited lifespan. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
If possible, follow this guide after your battery has fallen below 15% charge. While your MX Keys keyboard has a relatively small battery, any charged battery is a potential safety hazard if accidentally bent or punctured.
If your battery looks puffy or swollen, take extra precautions.
Neye ihtiyacın var
Slide the keyboard's power switch into the OFF position.
Unplug all cables from your keyboard.
Lay your keyboard down with the feet facing up on a clean work surface.
Bu adımda kullanılan alet:Tesa 61395 Tape$2.99
Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the recesses. Allow the surface to completely dry.
If you're installing new feet, remove them from their backing and firmly press the foot into place.
If you're reusing the feet, use a strip of double-sided tape to secure it in the recess.
Use the pointed end of a spudger to poke through each film so you can access the screw underneath.
Bu adımda kullanılan alet:Tweezers$3.99
Use a pair of angled tweezers to firmly grip the battery connector and slide it straight out of its socket.
Insert the connector into its socket so the side with raised plastic in the center is facing up.
Push on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
Bu adımda kullanılan alet:Tesa 61395 Tape$5.99
Use a spudger to remove any chunks of adhesive from the battery recess.
Use isopropyl alcohol (>90%) and a microfiber cloth to clean all adhesive residue from the recess.
If your replacement battery doesn't come with tape pre-installed, apply double-sided tape to the battery recess (not directly to the battery).
If your replacement battery has adhesive pre-installed, remove the plastic liner.
16 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Though @timo is technically correct with his calculations, I use this keyboard so often that after only eight months, the battery needs to be recharged about once every two days. Time to replace it! Such calculations can never account for usability. I use the backlight feature constantly which I'm sure is why my battery degraded as quickly as it did.
Yes I agree with you. Ever since Logi PC SW failed to control the auto-backlit function, my MX Keys just lights up every second. The battery status went poor after using it like 11 months.
Found this item on ebay as a replacement battery. Voltage, capacity, and dimensions are on spec, but it will require some soldering to move the connector to the replacement battery. I recommend clipping off the original connector closer to the battery to leave some slack for future replacements. Always use heat shrink to protect those solder connections and prevent shorting out the battery.
