Ana içeriğe geç
Logitech MX Vertical Feet Replacement
Neye ihtiyacın var
  1. Logitech MX Vertical Feet Replacement, Turn off the mouse: adım 1, 1 resimden 1.
    • Before you begin, flip the mouse's power switch down into the OFF position.
    • Unplug all cables from the mouse.
  2. Logitech MX Vertical Feet Replacement, Lay the mouse buttons-side down: adım 2, 1 resimden 1.
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it down on a soft towel to prevent wobble.
  3. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: adım 3, 2 resimden 1. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: adım 3, 2 resimden 2.
    • If you're planning to reuse your existing mouse feet, the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for two minutes.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you might warp the plastic shell.
  4. Logitech MX Vertical Feet Replacement, Remove the mouse feet: adım 4, 3 resimden 1. Logitech MX Vertical Feet Replacement, Remove the mouse feet: adım 4, 3 resimden 2. Logitech MX Vertical Feet Replacement, Remove the mouse feet: adım 4, 3 resimden 3.
    • Insert one arm of a pair of angled tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Feet Replacement: adım 5, 3 resimden 1. Logitech MX Vertical Feet Replacement: adım 5, 3 resimden 2. Logitech MX Vertical Feet Replacement: adım 5, 3 resimden 3.
    • Use the tweezers to peel the foot away from the mouse to completely remove it.
    • If you're reusing the foot, place it adhesive-side up on a clean surface.
  6. Logitech MX Vertical Feet Replacement: adım 6, 3 resimden 1. Logitech MX Vertical Feet Replacement: adım 6, 3 resimden 2. Logitech MX Vertical Feet Replacement: adım 6, 3 resimden 3.
    • Repeat the process to remove the other foot.
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
157.950 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.994 adet Kılavuz yazıldı
4Kılavuz Yorumları
Do you have to heat it to re-apply the feet?
Jimmy - Yanıt
Beste,
Weet je toevallig, waar ik de nieuwe voetjes van Logitech MX Vertical kan kopen?
Groeten,
peter smith
peter - Yanıt
where can you get new slide tape or feet?
Jerry - Yanıt
Aliexpress has it (look for MX Vertical glide)
or in this tutorial has a link to corepad.de website that sell them:
Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement
it should have been added to this tutorial as well.
tridy -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 34
Son 30 gün: 142
Her zaman: 5,190
