Ana içeriğe geç
Logitech MX Vertical Feet Replacement
Neye ihtiyacın var
  1. Logitech MX Vertical Feet Replacement, Turn off the mouse: adım 1, 1 resimden 1.
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Vertical Feet Replacement, Lay the mouse buttons-side down: adım 2, 1 resimden 1.
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it button-side down onto a soft towel to prevent wobble.
  3. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: adım 3, 2 resimden 1. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: adım 3, 2 resimden 2.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
    • Alternatively, a hair dryer or a heat gun may also be used, but be careful not to overheat the mouse.
  4. Logitech MX Vertical Feet Replacement, Remove the mouse feet: adım 4, 3 resimden 1. Logitech MX Vertical Feet Replacement, Remove the mouse feet: adım 4, 3 resimden 2. Logitech MX Vertical Feet Replacement, Remove the mouse feet: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Insert one arm of a pair of sharp tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Feet Replacement: adım 5, 3 resimden 1. Logitech MX Vertical Feet Replacement: adım 5, 3 resimden 2. Logitech MX Vertical Feet Replacement: adım 5, 3 resimden 3.
    • Use a pair of tweezers to peel the foot away from the mouse to completely remove it.
    • Place the foot adhesive-side up on a clean surface.
  6. Logitech MX Vertical Feet Replacement: adım 6, 3 resimden 1. Logitech MX Vertical Feet Replacement: adım 6, 3 resimden 2. Logitech MX Vertical Feet Replacement: adım 6, 3 resimden 3.
    • Insert a tweezer arm underneath the end of the second foot.
    • Peel the foot away from the mouse to completely remove it.
    • The foot should come away from the mouse without much force. If it feels stuck, apply more heat and try again.
    • During reassembly, remove any leftover adhesive before installing new feet.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
136.905 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.669 adet Kılavuz yazıldı
2Kılavuz Yorumları
Do you have to heat it to re-apply the feet?
Jimmy - Yanıt
Beste,
Weet je toevallig, waar ik de nieuwe voetjes van Logitech MX Vertical kan kopen?
Groeten,
peter smith
peter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 209
Her zaman: 3,957
