Ana içeriğe geç
Logitech Slim Folio Battery Replacement
Neye ihtiyacın var
  1. Logitech Slim Folio Battery Replacement, Open the case: adım 1, 3 resimden 1. Logitech Slim Folio Battery Replacement, Open the case: adım 1, 3 resimden 2. Logitech Slim Folio Battery Replacement, Open the case: adım 1, 3 resimden 3.
    • Open your case and lay it out flat.
  2. Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: adım 2, 3 resimden 1. Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: adım 2, 3 resimden 2. Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: adım 2, 3 resimden 3.
    • Grip the two case corners closest to the keyboard with your thumbs and pull them down, away from the iPad.
    • Remove the iPad from the case.
  3. Logitech Slim Folio Battery Replacement, Locate the battery tray: adım 3, 2 resimden 1. Logitech Slim Folio Battery Replacement, Locate the battery tray: adım 3, 2 resimden 2.
    • Fold the case in half, so the keyboard is facing up.
    • Locate the battery tray.
  4. Logitech Slim Folio Battery Replacement, Open the battery tray: adım 4, 3 resimden 1. Logitech Slim Folio Battery Replacement, Open the battery tray: adım 4, 3 resimden 2. Logitech Slim Folio Battery Replacement, Open the battery tray: adım 4, 3 resimden 3.
    • Insert the pointed end of a spudger into the access hole on the battery tray.
    • Push the spudger in, down, and pull the spudger towards you.
    • The battery tray should "click" open.
  5. Logitech Slim Folio Battery Replacement, Remove the battery tray: adım 5, 2 resimden 1. Logitech Slim Folio Battery Replacement, Remove the battery tray: adım 5, 2 resimden 2.
    • Insert the flat edge of the spudger into the top of the battery tray.
    • Push the battery tray out, away from the case, until you can grip it with your fingers.
  6. Logitech Slim Folio Battery Replacement: adım 6, 2 resimden 1. Logitech Slim Folio Battery Replacement: adım 6, 2 resimden 2.
    • Remove the battery tray.
  7. Logitech Slim Folio Battery Replacement, Remove the batteries: adım 7, 3 resimden 1. Logitech Slim Folio Battery Replacement, Remove the batteries: adım 7, 3 resimden 2. Logitech Slim Folio Battery Replacement, Remove the batteries: adım 7, 3 resimden 3.
    • Flip the battery tray over.
    • Use the pointed end of the spudger to push both batteries out of the tray.
    • Remove the batteries.
  8. Logitech Slim Folio Battery Replacement, Reinstallation tip: adım 8, 3 resimden 1. Logitech Slim Folio Battery Replacement, Reinstallation tip: adım 8, 3 resimden 2. Logitech Slim Folio Battery Replacement, Reinstallation tip: adım 8, 3 resimden 3.
    • To install new batteries:
    • Press one edge of a CR2032 coin cell battery against the contact arm, its text and "+" sign facing up.
    • Press to fully seat the battery.
    • Repeat for the second battery.
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
114.611 İtibar
339 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.303 adet Kılavuz yazıldı
12 Yorum
Excellent instructions. So easy - you made me a hero!
edspecial - Yanıt
So easy to do. I’m up and running again!
Susan Hallett - Yanıt
when you put the battery tray back in, you have to push it kind of hard to get it to go all the way in. I didn’t have a spudger but was able to use an ice pick (gently) and then a small flat screw driver.
pdmd - Yanıt
What if you don’t have a spider? Is there anything else that you can use to open the battery tray?
Kathy Pecsko - Yanıt
You can use something pointy instead of a Spudger. For example: A pair of scissors ✂️. You can open them with the pointy blade. Thanks!
Cheryl Xu -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 148
Son 7 gün: 1,484
Son 30 gün: 6,923
Her zaman: 204,563
