Ana içeriğe geç
M3D Micro Motor Replacement
Miguel Pina
Miguel Pina ve 3 diğer katkıda bulunanlar
En son April 23, 2020 tarihinde güncellendi
15 dakika
Kolay
When printing, your extruder may not work properly, the reason of this may be related to one of the two motors. If you determined that one of the motors could be the ones causing trouble, you will need to replace it. Through this guide we intend to show the step by step process that one must take to safely remove and replace the motor of a M3D Micro.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. M3D Micro Motor Replacement, M3D Micro Frame Removal: adım 1, 1 resimden 1.
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Motor Replacement: adım 2, 3 resimden 1. M3D Micro Motor Replacement: adım 2, 3 resimden 2. M3D Micro Motor Replacement: adım 2, 3 resimden 3.
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
    I could get it loose on one side. The other is firmly stuck. It does let me flip the head up to the side, but it won’t come loose without significant violence.
    Also, to the the first one loose, I have to pull the Y-rods so hard that they bend. Not plastic deformation, they are not ruined (I think) but the amount of force disturbs me.
    Ragnemalm - Yanıt
  3. M3D Micro Motor Replacement: adım 3, 2 resimden 1. M3D Micro Motor Replacement: adım 3, 2 resimden 2.
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
    This doesn’t work at all on my M3D. I had to force in a tool, a kitchen knife, to crack it open in each corner. THEN I can lift it up. (But I still can’t lift it off since I can’t remove the printer head. More force needed there.)
    Reassembly is harder, because you have six rods that must get into separate holes more or less simultaneously, and I guess those small metal rings on the top have a purpose too.
    Ragnemalm - Yanıt
  4. M3D Micro Motor Replacement, Motor: adım 4, 1 resimden 1.
    • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
    You forgot one step: How to remove the base!
    Ragnemalm - Yanıt
  5. M3D Micro Motor Replacement: adım 5, 2 resimden 1. M3D Micro Motor Replacement: adım 5, 2 resimden 2.
    • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
  6. M3D Micro Motor Replacement: adım 6, 2 resimden 1. M3D Micro Motor Replacement: adım 6, 2 resimden 2.
    • Once disconnected you will proceed to lift the motor using pliers.
  7. M3D Micro Motor Replacement: adım 7, 2 resimden 1. M3D Micro Motor Replacement: adım 7, 2 resimden 2.
    • Now, remove the motor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Miguel Pina
122 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G2
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,723
