Ana içeriğe geç
MacBook Air 13” Retina Display Late 2018 Fan Replacement
Neye ihtiyacın var
  1. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the screws securing the lower case: adım 1, 1 resimden 1.
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the lower case: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the battery: adım 3, 1 resimden 1.
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 4, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 4, 2 resimden 2.
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the right speaker: adım 5, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the right speaker: adım 5, 2 resimden 2.
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
  6. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the audio board: adım 6, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the audio board: adım 6, 2 resimden 2.
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
    • Remove the cable bracket.
  7. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 7, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
  8. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 8, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
  9. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the audio board: adım 9, 1 resimden 1.
    • Remove the following screws:
    • Two 4.3 mm, T5 Torx screws
    • One 2.4 mm, T3 Torx screw
  10. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 10, 1 resimden 1.
    • Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
  11. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 11, 1 resimden 1.
    • Remove the audio board.
  12. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Disconnect the fan: adım 12, 1 resimden 1.
    • Peel back the black tape covering the fan cable connector.
  13. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 13, 3 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 13, 3 resimden 2. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 13, 3 resimden 3.
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  14. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Separate the audio board cable: adım 14, 3 resimden 1. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Separate the audio board cable: adım 14, 3 resimden 2. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Separate the audio board cable: adım 14, 3 resimden 3.
    • Slide an opening pick under the audio board cable to slice through the adhesive securing it to the fan.
  15. MacBook Air 13” Retina Display Late 2018 Fan Replacement, Remove the fan: adım 15, 1 resimden 1.
    • Use a T5 Torx driver to remove the three 2.7 mm screws securing the fan.
  16. MacBook Air 13” Retina Display Late 2018 Fan Replacement: adım 16, 1 resimden 1.
    • Lift the fan out of the case and remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
190.029 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 133
Her zaman: 3,993
