Ana içeriğe geç
MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    FixBot'a Sor
    Yorum Ekle
  2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
    FixBot'a Sor
    Yorum Ekle
  3. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 3, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 3, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 3, 3 resimden 3.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    FixBot'a Sor
    Yorum Ekle
  4. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Battery Connector: adım 4, 1 resimden 1.
    • Remove the plastic cover adhered to the battery contact board.
    FixBot'a Sor
    Yorum Ekle
  5. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 5, 1 resimden 1.
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    FixBot'a Sor
    Yorum Ekle
  6. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 6, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 6, 2 resimden 2.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    FixBot'a Sor
    Yorum Ekle
  7. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 7, 1 resimden 1.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    FixBot'a Sor
    Yorum Ekle
  8. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 8, 2 resimden 2.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
    FixBot'a Sor
    Yorum Ekle
  9. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Battery Contact Board: adım 9, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Battery Contact Board: adım 9, 2 resimden 2.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    FixBot'a Sor
    Yorum Ekle
  10. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, I/O Board Data Cable: adım 10, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, I/O Board Data Cable: adım 10, 2 resimden 2.
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    FixBot'a Sor
    Yorum Ekle
  11. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 11, 2 resimden 2.
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  12. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 12, 1 resimden 1.
    • Lift and remove the I/O board data cable from the MacBook Pro.
    FixBot'a Sor
    Yorum Ekle
  13. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Right Speaker: adım 13, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Right Speaker: adım 13, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Right Speaker: adım 13, 3 resimden 3.
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
    FixBot'a Sor
    Yorum Ekle
  14. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 14, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 14, 2 resimden 2.
    • Wedge the pointed end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
    FixBot'a Sor
    Yorum Ekle
  15. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 15, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 15, 2 resimden 2.
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
    FixBot'a Sor
    Yorum Ekle
  16. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 16, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 16, 2 resimden 2.
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
    FixBot'a Sor
    Yorum Ekle
  17. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Left Speaker: adım 17, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Left Speaker: adım 17, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Left Speaker: adım 17, 3 resimden 3.
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
    FixBot'a Sor
    Yorum Ekle
  18. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 18, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 18, 2 resimden 2.
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  19. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 19, 1 resimden 1.
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    FixBot'a Sor
    Yorum Ekle
  20. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 20, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 20, 2 resimden 2.
    • Lift and remove the left speaker out of the upper case.
    FixBot'a Sor
    Yorum Ekle
  21. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, SSD Assembly: adım 21, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, SSD Assembly: adım 21, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, SSD Assembly: adım 21, 3 resimden 3.
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
    FixBot'a Sor
    Yorum Ekle
  22. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 22, 1 resimden 1.
    • Remove the SSD assembly from the upper case.
    FixBot'a Sor
    Yorum Ekle
  23. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Battery: adım 23, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Battery: adım 23, 2 resimden 2.
    • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
    FixBot'a Sor
    Yorum Ekle
  24. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 24, 1 resimden 1.
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    FixBot'a Sor
    Yorum Ekle
  25. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 25, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 25, 2 resimden 2.
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
    FixBot'a Sor
    Yorum Ekle
  26. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 26, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 26, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 26, 3 resimden 3.
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    FixBot'a Sor
    Yorum Ekle
  27. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 27, 1 resimden 1.
    • Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    FixBot'a Sor
    Yorum Ekle
  28. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 28, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 28, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 28, 3 resimden 3.
    Plastic Cards
    $2.99
    • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
    • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
    FixBot'a Sor
    Yorum Ekle
  29. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 29, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 29, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 29, 3 resimden 3.
    • Insert the spudger along the left-hand side of the leftmost battery cell.
    • Run the spudger up along the left side of the leftmost battery cell.
    • Slightly pry the leftmost battery cell to release it from the adhesive.
    FixBot'a Sor
    Yorum Ekle
  30. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 30, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 30, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 30, 3 resimden 3.
    • Repeat the above steps to separate the adjacent battery cell from its adhesive:
    • Apply a few drops of liquid adhesive remover under the battery cell.
    • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
    FixBot'a Sor
    Yorum Ekle
  31. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 31, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 31, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 31, 3 resimden 3.
    • Insert the flat end of a spudger underneath the larger leftmost battery cell.
    • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
    • Pry the larger leftmost battery cell up off the upper case.
    FixBot'a Sor
    Yorum Ekle
  32. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 32, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 32, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 32, 3 resimden 3.
    • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
    • Leave the battery cells resting on top of the upper case as shown in the third picture.
    FixBot'a Sor
    Yorum Ekle
  33. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 33, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 33, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 33, 3 resimden 3.
    • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
    • Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
    • Be careful not to puncture or otherwise damage the battery cells.
    FixBot'a Sor
    Yorum Ekle
  34. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 34, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 34, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 34, 3 resimden 3.
    • Lift the battery as a whole up out of the upper case, and remove the battery.
    • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
    FixBot'a Sor
    Yorum Ekle
  35. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Logic Board Assembly: adım 35, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Logic Board Assembly: adım 35, 2 resimden 2.
    • Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    FixBot'a Sor
    Yorum Ekle
  36. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 36, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 36, 2 resimden 2.
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  37. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 37, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 37, 2 resimden 2.
    • Move the iSight camera cable aside.
    FixBot'a Sor
    Yorum Ekle
  38. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 38, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 38, 2 resimden 2.
    • Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board.
    • Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  39. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 39, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 39, 2 resimden 2.
    • Use the tip of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  40. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 40, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 40, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 40, 3 resimden 3.
    • Use the tip of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  41. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 41, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 41, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 41, 3 resimden 3.
    • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  42. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 42, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 42, 2 resimden 2.
    • Use the tip of a spudger to rotate the pull tab secured to the display data cable lock toward the DC-In side of the computer.
    FixBot'a Sor
    Yorum Ekle
  43. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 43, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 43, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 43, 3 resimden 3.
    • Gently push the edges of the display data cable connector away from its socket on the logic board.
    • It is recommended "walk" the connector out of its socket. Simply push the top and bottom corners of the connector and carefully "walk it out" of its socket.
    • Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
    FixBot'a Sor
    Yorum Ekle
  44. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 44, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 44, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 44, 3 resimden 3.
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Carefully pull the left fan ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  45. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 45, 1 resimden 1.
    • Move the left fan ribbon cable aside to reveal a hidden screw securing the logic board assembly to the upper case.
    FixBot'a Sor
    Yorum Ekle
  46. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 46, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 46, 2 resimden 2.
    • Remove the following screws securing the logic board to the upper case:
    • Eight 3.3 mm T5 Torx screws
    • One Phillips #00 screw
    • Two 3.1 mm T5 Torx screws
    • Remove two more screws, from the MagSafe DC-In board in the upper right corner (second image).
    • Two 3.4 mm T5 Torx screws
    FixBot'a Sor
    Yorum Ekle
  47. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 47, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 47, 2 resimden 2.
    • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding any cables and the I/O ports that may get caught during removal.
    • Pull the right I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
    FixBot'a Sor
    Yorum Ekle
  48. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, I/O Board: adım 48, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, I/O Board: adım 48, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, I/O Board: adım 48, 3 resimden 3.
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
    FixBot'a Sor
    Yorum Ekle
  49. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 49, 1 resimden 1.
    • Remove the following two screws securing the I/O board to the upper case:
    • One 3.53 mm T5 Torx screw
    • One 4.89 mm T8 Torx standoff screw
    FixBot'a Sor
    Yorum Ekle
  50. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 50, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 50, 2 resimden 2.
    • Carefully pull and remove the I/O board away from its recess in the upper case.
    FixBot'a Sor
    Yorum Ekle
  51. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Headphone Jack Assembly: adım 51, 1 resimden 1.
    • Remove the two 3.4 mm T5 Torx screws securing the headphone jack to the upper case.
    FixBot'a Sor
    Yorum Ekle
  52. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 52, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 52, 2 resimden 2.
    • Lift and remove the headphone jack out of the upper case.
    FixBot'a Sor
    Yorum Ekle
  53. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Display Assembly: adım 53, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Display Assembly: adım 53, 2 resimden 2.
    • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
    FixBot'a Sor
    Yorum Ekle
  54. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 54, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 54, 2 resimden 2.
    • Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case.
    FixBot'a Sor
    Yorum Ekle
  55. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 55, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 55, 2 resimden 2.
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
    FixBot'a Sor
    Yorum Ekle
  56. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 56, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 56, 2 resimden 2.
    • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    FixBot'a Sor
    Yorum Ekle
  57. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 57, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 57, 2 resimden 2.
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
    FixBot'a Sor
    Yorum Ekle
  58. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 58, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 58, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 58, 3 resimden 3.
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
    FixBot'a Sor
    Yorum Ekle
  59. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Trackpad: adım 59, 1 resimden 1.
    • Remove the following screws securing the trackpad to the upper case:
    • Four 1.4 mm Phillips #000 screws
    FixBot'a Sor
    Yorum Ekle
  60. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 60, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 60, 2 resimden 2.
    • Wedge the spudger between the trackpad ribbon cable and the upper case.
    • Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
    FixBot'a Sor
    Yorum Ekle
  61. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 61, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 61, 2 resimden 2.
    • Insert the tip of a spudger in between the trackpad ribbon cable and the upper case.
    • Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
    FixBot'a Sor
    Yorum Ekle
  62. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 62, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 62, 2 resimden 2.
    • Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case.
    • Remove the trackpad from the upper case.
    FixBot'a Sor
    Yorum Ekle
  63. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Microphone Assembly: adım 63, 1 resimden 1.
    • For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
    • With the heat gun set to low, heat the microphone assembly to loosen the adhesive attaching it to the upper case.
    • Be very careful not to overheat the microphones or upper case. Keep in mind that the plastic keyboard is on the other side—too much heat in a single place can melt keys.
    FixBot'a Sor
    Yorum Ekle
  64. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 64, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 64, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 64, 3 resimden 3.
    • Use the tip of a spudger to remove the piece of tape covering one of two microphones.
    • Grasp the piece of tape with a pair of tweezers and remove it.
    FixBot'a Sor
    Yorum Ekle
  65. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 65, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 65, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 65, 3 resimden 3.
    • Repeat the same procedure as the previous step to remove the tape covering the second microphone.
    FixBot'a Sor
    Yorum Ekle
  66. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 66, 3 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 66, 3 resimden 2. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 66, 3 resimden 3.
    • Wedge the tip of a spudger underneath the microphone assembly cable.
    • Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
    FixBot'a Sor
    Yorum Ekle
  67. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 67, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 67, 2 resimden 2.
    • Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive.
    • At this point the second microphone should be completely detached from the upper case.
    FixBot'a Sor
    Yorum Ekle
  68. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 68, 2 resimden 1. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 68, 2 resimden 2.
    • Carefully pry the first microphone up off the upper case.
    FixBot'a Sor
    Yorum Ekle
  69. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement: adım 69, 1 resimden 1.
    • Lift and remove the microphone assembly out of the upper case.
    FixBot'a Sor
    Yorum Ekle
  70. MacBook Pro 13" Retina Display Early 2013 Upper Case Replacement, Upper Case: adım 70, 1 resimden 1.
    • Upper case remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.674 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
27.624 adet Kılavuz yazıldı
1Rehber Yorum
Always order a new battery. Saves you another repair.
John - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 71
Her zaman: 18,860
