Giriş
Use this guide to replace an aging battery. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
Tilt the battery away from the logic board enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
394 farklı kişi bu kılavuzu tamamladı.
32Kılavuz Yorumları
I would only add one additional part (and half of a step). Get so,e Threadlock Blue 242 and apply a little bit to the threads of the screws when re-placing the back case. If you open the back up a lot, this helps keep the screws from coming undone and falling out (for years before I figured this out I used to have patches of gaffer's tape on the bottom side of my computer).
Cela c'est bien passé, j'ai commandé un tournevis Y, mais je me suis rendu compte que j'en avais déjà un à la maison... Probablement, moins dispendieux d'acheter dans un magasin d'occasion d'informatique.
J'ai payé 42,44$CAN avec FedEx pour les frais de douanes en plus du prix de la batterie autour de 175$CAN, presque 200$CAN pour une batterie plus un tournevis Y. Riddicule!! Ebay doit être une meilleure aubaine côté prix.
Toutefois, je dois admettre que le nombre de cycle est plus élévée avec cette batterie, on parle de 4800 cycles de recharge disponible tandis que la batterie originale de Apple comptait 1000 cycles. La batterie une fois installée est chargé à 75% environ. Tutoriel très simple et facile à comprendre même pour les francophones, je le recommande.
On my Macbook Pro 15", Mid 2010, a Y0 trip-wing bit worked much better than the Y1.
What kind of battery is compatible with the Macbook pro 15 mid 2010 A1286? Thanks in advance.
