Ana içeriğe geç
Meta Quest 2 Controller Board Replacement
Neye ihtiyacın var
  1. Meta Quest 2 Controller Board Replacement, Remove the battery cover: adım 1, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the battery cover: adım 1, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
  2. Meta Quest 2 Controller Board Replacement, Remove the wrist strap: adım 2, 2 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the wrist strap: adım 2, 2 resimden 2.
    • Use your fingers to grasp the wrist strap near the anchor peg.
    • Lift the wrist strap anchor peg straight out of its recess.
    • Remove the wrist strap.
  3. Meta Quest 2 Controller Board Replacement, Loosen the faceplate adhesive: adım 3, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
    Why is this step needed? Yes there is adhesive on it, but it isn't that bad.
    DAB ARMY - Yanıt
    you dont need it, prob better to have it but not required to get the cover off
    jek - Yanıt
    For anyone stumbling across this like me, I can agree with the others: it is almost definitely a nice to have I'm sure, but I was able to get in just fine using an opening pick and opening tool.
    Aranohr - Yanıt
  4. Meta Quest 2 Controller Board Replacement, Loosen the controller faceplate: adım 4, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Loosen the controller faceplate: adım 4, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Loosen the controller faceplate: adım 4, 3 resimden 3.
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
  5. Meta Quest 2 Controller Board Replacement: adım 5, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 5, 2 resimden 2.
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
  6. Meta Quest 2 Controller Board Replacement: adım 6, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 6, 2 resimden 2.
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
  7. Meta Quest 2 Controller Board Replacement, Remove the faceplate: adım 7, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the faceplate: adım 7, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Remove the faceplate: adım 7, 3 resimden 3.
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
  8. Meta Quest 2 Controller Board Replacement, Loosen the controller ring shell: adım 8, 2 resimden 1. Meta Quest 2 Controller Board Replacement, Loosen the controller ring shell: adım 8, 2 resimden 2.
    • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
    • Two 4.7 mm‑long screws
    • Two 5.9 mm‑long screws
    those top screws in red are in very tight, and at an angle that prevents using a long screwdriver. I've found the only way I could get them out is using a bit, held down by my finger at the appropriate angle, while turning it with pliers.
    Ben Klopfenstein - Yanıt
    I wasn't able to remove the screws in red with a T5 bit, but switching to a T4 bit did the trick for me
    Aranohr - Yanıt
    same, used T4 instead
    Martin Samuelsson -
  9. Meta Quest 2 Controller Board Replacement: adım 9, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 9, 2 resimden 2.
    • Press the point of a spudger firmly against the white alignment square to release the ring shell.
  10. Meta Quest 2 Controller Board Replacement, Remove the controller ring shell: adım 10, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the controller ring shell: adım 10, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Remove the controller ring shell: adım 10, 3 resimden 3.
    • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
    • Gently lift the ring shell up and away from the controller to unclip it from the controller.
    • Remove the controller ring shell.
  11. Meta Quest 2 Controller Board Replacement, Loosen the side shell: adım 11, 2 resimden 1. Meta Quest 2 Controller Board Replacement, Loosen the side shell: adım 11, 2 resimden 2.
    • Use a Torx T5 driver to remove the five screws:
    • One 11.5 mm‑long screw
    • Three 5.9 mm‑long screws
    • One 18.2 mm‑long screw
  12. Meta Quest 2 Controller Board Replacement, Remove the battery label: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers and your fingers to peel the battery information label out from the battery compartment.
    • If you want to reuse this sticker, be careful not to tear it. If it’s difficult to peel, apply a heated iOpener to it for a minute to soften the label adhesive.
  13. Meta Quest 2 Controller Board Replacement, Loosen the side shell: adım 13, 2 resimden 1. Meta Quest 2 Controller Board Replacement, Loosen the side shell: adım 13, 2 resimden 2.
    • Use a Torx T5 driver to remove the four 5.9 mm‑long screws securing the side shell to the controller:
    • Three screws inside the battery compartment
    • One screw near the corner of the battery compartment
  14. Meta Quest 2 Controller Board Replacement: adım 14, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 14, 2 resimden 2.
    • Pull the bottom of the side shell slightly away from the controller to loosen the shell.
    • You may hear a few clicks as the clips release. This is normal.
  15. Meta Quest 2 Controller Board Replacement: adım 15, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 15, 2 resimden 2.
    • Part of the side shell is looped around a screw post. In this step, you’ll spread the screw post apart enough to slip the shell out.
    • Insert the flat end of a spudger into the gap between the controller ring and the front shell.
    • The front shell is the plastic frame part below the front trigger.
    • Twist the spudger to widen the gap between the front shell and the controller.
    • Position the spudger so that it can stay in place without you holding the tool.
  16. Meta Quest 2 Controller Board Replacement, Remove the side shell: adım 16, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the side shell: adım 16, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Remove the side shell: adım 16, 3 resimden 3.
    • Guide the looped part of the side shell through the screw post gap.
    • Remove the side shell.
  17. Meta Quest 2 Controller Board Replacement, Reassembly note: adım 17, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Reassembly note: adım 17, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Reassembly note: adım 17, 3 resimden 3.
    • During reassembly:
    • Spread the screw post wide enough to loop the side shell back around it.
    • Be careful not to pinch the antenna cable or the tracking flex cable as you reposition the side shell.
  18. Meta Quest 2 Controller Board Replacement, Remove the Controller Front Shell: adım 18, 1 resimden 1.
    • Use a spudger or an opening pick to gently pry the shell from the battery compartment side first.
    • Once it pops open, turn the controller over to remove the front shell.
    • If you have trouble, move to the next step.
  19. Meta Quest 2 Controller Board Replacement: adım 19, 3 resimden 1. Meta Quest 2 Controller Board Replacement: adım 19, 3 resimden 2. Meta Quest 2 Controller Board Replacement: adım 19, 3 resimden 3.
    • If you successfully removed the front shell, skip this step.
    • Grasp the front shell near the bottom of the controller.
    • Lift and pull the bottom edge of the front shell outwards slightly to clear the plastic alignment peg.
    • The alignment peg breaks easily. Make sure you lift the shell enough to clear it.
    Note: Clearing the alignment peg should not be difficult if you open the cover from the other side first as shown in my edit.
    Seby - Yanıt
    Thanks Seby for your contribution! I've formatted the steps a little to include your step.
    Arthur Shi -
  20. Meta Quest 2 Controller Board Replacement: adım 20, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 20, 2 resimden 2.
    • Pull the front shell away from the controller and remove it.
  21. Meta Quest 2 Controller Board Replacement, Remove the front trigger pin: adım 21, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the front trigger pin: adım 21, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Remove the front trigger pin: adım 21, 3 resimden 3.
    • Use a driver bit (such as the Torx T5) or the point of a spudger to push the front trigger pin out from the side shown. Pushing from the opposite side can cause the pin to rip the sensor cable.
    • For better reach, you can also use a straightened paper clip or the point of your tweezers.
    I found this step very difficult. It required a lot of pressure to push the peg through. Make sure you push the peg from the side shown or it can tear the LED cable shown under the tip of the torx driver.
    Seby - Yanıt
    This required a LOT of force on the pin to jar it loose. Just be mindful that you push in the way that nothing breaks when the pin abruptly loosens.
    eliasp02 - Yanıt
  22. Meta Quest 2 Controller Board Replacement: adım 22, 1 resimden 1.
    • Hold the front trigger with your finger to prevent the trigger from flying out.
    • Use tweezers or your fingers to pull the trigger pin out.
  23. Meta Quest 2 Controller Board Replacement, Remove the front trigger: adım 23, 2 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the front trigger: adım 23, 2 resimden 2.
  24. Meta Quest 2 Controller Board Replacement, Disconnect the controller board: adım 24, 2 resimden 1. Meta Quest 2 Controller Board Replacement, Disconnect the controller board: adım 24, 2 resimden 2.
    • Use a clean fingernail or tweezers to flip up the ZIF socket's lock bar securing the outer tracking flex cable.
  25. Meta Quest 2 Controller Board Replacement: adım 25, 2 resimden 1. Meta Quest 2 Controller Board Replacement: adım 25, 2 resimden 2.
    • Use tweezers to grasp the outer tracking flex cable by its pull tab and pull it out of its ZIF socket.
  26. Meta Quest 2 Controller Board Replacement: adım 26, 3 resimden 1. Meta Quest 2 Controller Board Replacement: adım 26, 3 resimden 2. Meta Quest 2 Controller Board Replacement: adım 26, 3 resimden 3.
    • Use the same procedure to unlock and disconnect the inner tracking flex cable from its ZIF socket.
  27. Meta Quest 2 Controller Board Replacement: adım 27, 3 resimden 1. Meta Quest 2 Controller Board Replacement: adım 27, 3 resimden 2. Meta Quest 2 Controller Board Replacement: adım 27, 3 resimden 3.
    • Use a clean fingernail or tweezers to unlock and disconnect the joystick flex cable from its ZIF socket.
  28. Meta Quest 2 Controller Board Replacement: adım 28, 3 resimden 1. Meta Quest 2 Controller Board Replacement: adım 28, 3 resimden 2. Meta Quest 2 Controller Board Replacement: adım 28, 3 resimden 3.
    • Insert one arm of a pair of tweezers under the metal neck of the antenna cable.
    • Pry straight up to disconnect the antenna from the controller board.
    • Gently pull the antenna to unclip it from its grounding clip.
  29. Meta Quest 2 Controller Board Replacement: adım 29, 3 resimden 1. Meta Quest 2 Controller Board Replacement: adım 29, 3 resimden 2. Meta Quest 2 Controller Board Replacement: adım 29, 3 resimden 3.
    • Use a clean fingernail or tweezers to unlock and disconnect the interconnect flex cable from its ZIF socket.
    i ripped the cable where can i find a replacement
    Crippled Dorito - Yanıt
  30. Meta Quest 2 Controller Board Replacement, Loosen the battery shell: adım 30, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Loosen the battery shell: adım 30, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Loosen the battery shell: adım 30, 3 resimden 3.
    • The battery shell is the plastic frame part that holds the batteries.
    • Use your fingers to twist the battery shell slightly so that its edge near the thumbstick clicks out of place.
  31. Meta Quest 2 Controller Board Replacement: adım 31, 3 resimden 1. Meta Quest 2 Controller Board Replacement: adım 31, 3 resimden 2. Meta Quest 2 Controller Board Replacement: adım 31, 3 resimden 3.
    • There’s a friction assembly near the vibration motor that needs to separate in order to remove the battery shell.
    • Gently wiggle the battery shell as you pull it away from the controller.
    • Remove the battery shell.
  32. Meta Quest 2 Controller Board Replacement, Unfasten the controller board: adım 32, 1 resimden 1.
    • Use a Torx T5 driver to remove the four 7.5 mm‑long screws securing the controller board.
    • During reassembly, be careful not to overtighten these screws, or you may break them.
  33. Meta Quest 2 Controller Board Replacement, Remove the controller board: adım 33, 3 resimden 1. Meta Quest 2 Controller Board Replacement, Remove the controller board: adım 33, 3 resimden 2. Meta Quest 2 Controller Board Replacement, Remove the controller board: adım 33, 3 resimden 3.
    • Use your fingers to lift the controller board out of the shell and remove it.
    If the joystick spring came out during disassembly - make sure to put it back under the board before screwing it in!
    Murray Groves - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
283.063 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.536 adet Kılavuz yazıldı
2 Yorum
Where can I purchase a controller board for my Meta Quest 2 right controller?
Scott Hepler - Yanıt
How can I reattach the ZIF socket to the circuit board?
Toni Jones - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 47
Son 30 gün: 221
Her zaman: 2,790
