Ana içeriğe geç
Mi 11 Screen Replacement
Neye ihtiyacın var
  1. Mi 11 Screen Replacement, Heat the rear glass: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  2. Mi 11 Screen Replacement, Insert an opening pick: adım 2, 3 resimden 1. Mi 11 Screen Replacement, Insert an opening pick: adım 2, 3 resimden 2. Mi 11 Screen Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  3. Mi 11 Screen Replacement, Slice the adhesive: adım 3, 2 resimden 1. Mi 11 Screen Replacement, Slice the adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  4. Mi 11 Screen Replacement, Slice the adhesive: adım 4, 3 resimden 1. Mi 11 Screen Replacement, Slice the adhesive: adım 4, 3 resimden 2. Mi 11 Screen Replacement, Slice the adhesive: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your Xiaomi Mi 11 to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  5. Mi 11 Screen Replacement: adım 5, 2 resimden 1. Mi 11 Screen Replacement: adım 5, 2 resimden 2.
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  6. Mi 11 Screen Replacement: adım 6, 2 resimden 1. Mi 11 Screen Replacement: adım 6, 2 resimden 2.
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    FixBot'a Sor
    Yorum Ekle
  7. Mi 11 Screen Replacement, Remove the rear glass: adım 7, 2 resimden 1. Mi 11 Screen Replacement, Remove the rear glass: adım 7, 2 resimden 2.
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    FixBot'a Sor
    Yorum Ekle
  8. Mi 11 Screen Replacement, Unfasten the metal bracket screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the screws securing the connector metal bracket and the camera cover:
    • Two 4.4 mm-long screws
    • One 4.9 mm-long screw
    • Two 3.9 mm-long screws
    FixBot'a Sor
    Yorum Ekle
  9. Mi 11 Screen Replacement, Remove the metal bracket: adım 9, 3 resimden 1. Mi 11 Screen Replacement, Remove the metal bracket: adım 9, 3 resimden 2. Mi 11 Screen Replacement, Remove the metal bracket: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the connector bracket by pulling it in the direction of the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Mi 11 Screen Replacement, Disconnect the flash assembly: adım 10, 2 resimden 1. Mi 11 Screen Replacement, Disconnect the flash assembly: adım 10, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  11. Mi 11 Screen Replacement, Disconnect the right battery cable: adım 11, 2 resimden 1. Mi 11 Screen Replacement, Disconnect the right battery cable: adım 11, 2 resimden 2.
    • The battery of the Xiaomi Mi 11 has two separate flex cables. You need to disconnect both in order to disconnect the battery completely.
    • Use a spudger to disconnect the right battery cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  12. Mi 11 Screen Replacement, Remove the camera cover: adım 12, 2 resimden 1. Mi 11 Screen Replacement, Remove the camera cover: adım 12, 2 resimden 2.
    • Use your fingers or a pair of tweezers to carefully lift the camera cover including the flash assembly off the camera lenses and remove it.
    FixBot'a Sor
    Yorum Ekle
  13. Mi 11 Screen Replacement, Unfasten the motherboard cover screws: adım 13, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  14. Mi 11 Screen Replacement, Pry up the motherboard cover: adım 14, 2 resimden 1. Mi 11 Screen Replacement, Pry up the motherboard cover: adım 14, 2 resimden 2.
    • Insert an opening pick underneath the bottom left edge of the motherboard cover.
    • Slide the opening pick along the left edge of the motherboard cover and pry it up.
    FixBot'a Sor
    Yorum Ekle
  15. Mi 11 Screen Replacement, Remove the motherboard cover: adım 15, 2 resimden 1. Mi 11 Screen Replacement, Remove the motherboard cover: adım 15, 2 resimden 2.
    • Remove the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  16. Mi 11 Screen Replacement, Disconnect the left battery cable: adım 16, 2 resimden 1. Mi 11 Screen Replacement, Disconnect the left battery cable: adım 16, 2 resimden 2.
    • Use a spudger to disconnect the left battery cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  17. Mi 11 Screen Replacement, Disconnect the right interconnect cable: adım 17, 2 resimden 1. Mi 11 Screen Replacement, Disconnect the right interconnect cable: adım 17, 2 resimden 2.
    • Use a spudger to disconnect the right interconnect cable from the motherboard by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  18. Mi 11 Screen Replacement, Remove the right interconnect cable: adım 18, 3 resimden 1. Mi 11 Screen Replacement, Remove the right interconnect cable: adım 18, 3 resimden 2. Mi 11 Screen Replacement, Remove the right interconnect cable: adım 18, 3 resimden 3.
    • Use a spudger to disconnect the right interconnect cable from the daughterboard by prying the connector straight up from its socket.
    • Remove the right interconnect cable.
    FixBot'a Sor
    Yorum Ekle
  19. Mi 11 Screen Replacement, Disconnect the display flex cable: adım 19, 2 resimden 1. Mi 11 Screen Replacement, Disconnect the display flex cable: adım 19, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  20. Mi 11 Screen Replacement, Loosen the display adhesive: adım 20, 1 resimden 1.
    • Apply a heated iOpener or a heat gun to the screen for two minutes to loosen the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  21. Mi 11 Screen Replacement, Insert an opening pick: adım 21, 3 resimden 1. Mi 11 Screen Replacement, Insert an opening pick: adım 21, 3 resimden 2. Mi 11 Screen Replacement, Insert an opening pick: adım 21, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction cup to the bottom edge of the phone.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick in the gap between the midframe and the screen.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive. Leave the opening pick in place to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  22. Mi 11 Screen Replacement, Slice the adhesive: adım 22, 2 resimden 1. Mi 11 Screen Replacement, Slice the adhesive: adım 22, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  23. Mi 11 Screen Replacement: adım 23, 3 resimden 1. Mi 11 Screen Replacement: adım 23, 3 resimden 2. Mi 11 Screen Replacement: adım 23, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to for 1-2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive. Leave it in the top left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  24. Mi 11 Screen Replacement: adım 24, 2 resimden 1. Mi 11 Screen Replacement: adım 24, 2 resimden 2.
    • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  25. Mi 11 Screen Replacement: adım 25, 2 resimden 1. Mi 11 Screen Replacement: adım 25, 2 resimden 2.
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
    FixBot'a Sor
    Yorum Ekle
  26. Mi 11 Screen Replacement, Remove the screen: adım 26, 3 resimden 1. Mi 11 Screen Replacement, Remove the screen: adım 26, 3 resimden 2. Mi 11 Screen Replacement, Remove the screen: adım 26, 3 resimden 3.
    • Thread the display flex cable through the gap in the midframe and remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
9 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
260.899 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
27.624 adet Kılavuz yazıldı
2Kılavuz Yorumları
After new screen substitution is Impossible to add new fingerprint
Aldo Della Monica - Yanıt Paylaş
You need to calibrate the fingerprint sensor. There are guides on Youtube and parts on Aliexpress
Nicolas SCHMIT - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 42
Son 30 gün: 191
Her zaman: 14,807
