Ana içeriğe geç
Microsoft Surface Laptop 3 15" SSD Replacement
Neye ihtiyacın var
  1. Microsoft Surface Laptop 3 15" SSD Replacement, Prepare your device: adım 1, 2 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Prepare your device: adım 1, 2 resimden 2.
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
  2. Microsoft Surface Laptop 3 15" SSD Replacement, Flip the laptop over: adım 2, 2 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Flip the laptop over: adım 2, 2 resimden 2.
    • Flip the laptop over and place it on your work surface, feet facing up.
  3. Microsoft Surface Laptop 3 15" SSD Replacement, Removal tip: adım 3, 2 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Removal tip: adım 3, 2 resimden 2.
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  4. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the rear feet: adım 4, 3 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the rear feet: adım 4, 3 resimden 2. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the rear feet: adım 4, 3 resimden 3.
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  5. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the front feet: adım 5, 3 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the front feet: adım 5, 3 resimden 2. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the front feet: adım 5, 3 resimden 3.
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  6. Microsoft Surface Laptop 3 15" SSD Replacement, Reassembly tip: adım 6, 2 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Reassembly tip: adım 6, 2 resimden 2.
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  7. Microsoft Surface Laptop 3 15" SSD Replacement, Reassembly tip: adım 7, 3 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Reassembly tip: adım 7, 3 resimden 2. Microsoft Surface Laptop 3 15" SSD Replacement, Reassembly tip: adım 7, 3 resimden 3.
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  8. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the upper case screws: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  9. Microsoft Surface Laptop 3 15" SSD Replacement, Open the display: adım 9, 3 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Open the display: adım 9, 3 resimden 2. Microsoft Surface Laptop 3 15" SSD Replacement, Open the display: adım 9, 3 resimden 3.
    • Flip the device over.
    • Open the display as far as it will go.
  10. Microsoft Surface Laptop 3 15" SSD Replacement, Lift up the upper case: adım 10, 3 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Lift up the upper case: adım 10, 3 resimden 2. Microsoft Surface Laptop 3 15" SSD Replacement, Lift up the upper case: adım 10, 3 resimden 3.
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  11. Microsoft Surface Laptop 3 15" SSD Replacement, Disconnect the ribbon cable: adım 11, 3 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Disconnect the ribbon cable: adım 11, 3 resimden 2. Microsoft Surface Laptop 3 15" SSD Replacement, Disconnect the ribbon cable: adım 11, 3 resimden 3.
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  12. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the upper case: adım 12, 2 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the upper case: adım 12, 2 resimden 2.
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  13. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the SSD screw: adım 13, 1 resimden 1.
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  14. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the SSD: adım 14, 2 resimden 1. Microsoft Surface Laptop 3 15" SSD Replacement, Remove the SSD: adım 14, 2 resimden 2.
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
7 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
155.981 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.788 adet Kılavuz yazıldı
2Kılavuz Yorumları
whats the max size ssd i can replace my 256gb with here please - as a 1tb at the very least would be perfect - as i do a lot of photoshop work here ..
with major major thanks in advance, j
James Shaw - Yanıt
Very pleased with the redesign of these units, much easier to repiar.
Doug Harris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 58
Son 30 gün: 296
Her zaman: 25,559
