Giriş
The battery of the Milwaukee Circular Saw 263020 B57A 2008 tends to deteriorate over a long period of time which leads to a strained battery. The way you can tell if your battery is strained is if you have issues such as the saw is idle, it doesn't power on, or low usage time between charges. You can also use this troubleshooting page before continuing with replacement. If the battery in your saw is strained, damaged or not charging, use this guide to remove and replace your battery.
In step five of this guide, you will be using a soldering gun, which is a tool that melts the solder (a metal alloy with a low melting point). Carefully follow this guide to avoid burning yourself. Be sure to power off the solder machine after use.
Neye ihtiyacın var
Remove the nine 6 mm screws using a Torx T4 screwdriver.
Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
Slowly remove the battery from its slot with your hand while watching out for the spring below.
Remove the spring that is located under the battery compartment and set it aside for later.
Bir başkası bu kılavuzu tamamladı.
