Ana içeriğe geç
Milwaukee M18 2606-20 Trigger Replacement
Markus Eldridge
Markus Eldridge ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
30 - 50 dakika
Zor
If you need to replace the trigger on your Milwaukee M18 cordless power drill (Model # 2606-20) see this guide on how to remove it. The trigger is what tells the drill to start moving when pulled. Some reasons to replace the trigger are if it is obstructed or it is not engaging. The final steps require some soldering, so see our How to Solder and Desolder Connections Guide for more information on soldering best practice.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Milwaukee M18 2606-20 Trigger Replacement, Trigger: adım 1, 2 resimden 1. Milwaukee M18 2606-20 Trigger Replacement, Trigger: adım 1, 2 resimden 2.
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
    • Remove the two 21 mm screws, using the T3 Torx Screwdriver, from the top of the case.
  2. Milwaukee M18 2606-20 Trigger Replacement: adım 2, 3 resimden 1. Milwaukee M18 2606-20 Trigger Replacement: adım 2, 3 resimden 2. Milwaukee M18 2606-20 Trigger Replacement: adım 2, 3 resimden 3.
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
  3. Milwaukee M18 2606-20 Trigger Replacement: adım 3, 2 resimden 1. Milwaukee M18 2606-20 Trigger Replacement: adım 3, 2 resimden 2.
    • Peel back the sticker at the bottom of the drill handle.
  4. Milwaukee M18 2606-20 Trigger Replacement: adım 4, 2 resimden 1. Milwaukee M18 2606-20 Trigger Replacement: adım 4, 2 resimden 2.
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  5. Milwaukee M18 2606-20 Trigger Replacement: adım 5, 2 resimden 1. Milwaukee M18 2606-20 Trigger Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Unplug the 4-pin connector, using the tweezers, from the circuit board.
  6. Milwaukee M18 2606-20 Trigger Replacement: adım 6, 3 resimden 1. Milwaukee M18 2606-20 Trigger Replacement: adım 6, 3 resimden 2. Milwaukee M18 2606-20 Trigger Replacement: adım 6, 3 resimden 3.
    • Desolder the wires soldered to the trigger.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 30
Son 30 gün: 101
Her zaman: 5,316
