Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
How to remove the cutting head's bottom cover for device service or part replacement in a Mk Diamond Wet Saw MK660 2010.
Neye ihtiyacın var
Loosen the plastic knob holding the saw's cutting head in place.
Lower the cutting head while keeping it steady.
Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
Pull the entire cutting head straight off the shaft holding it in place.
Remove the eight Phillips #2 screws on the underside of the cutting head.
