Ana içeriğe geç
Monster Soundstage S2 Front Speakers Replacement
Josue A Melgar
Josue A Melgar ve 3 diğer katkıda bulunanlar
En son May 2, 2022 tarihinde güncellendi
5 dakika
Kolay
This guide can be used to replace the front speakers of Monster Soundstage S2 speaker.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Monster Soundstage S2 Front Speakers Replacement, Speaker Grille: adım 1, 2 resimden 1. Monster Soundstage S2 Front Speakers Replacement, Speaker Grille: adım 1, 2 resimden 2.
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Front Speakers Replacement: adım 2, 3 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 2, 3 resimden 2. Monster Soundstage S2 Front Speakers Replacement: adım 2, 3 resimden 3.
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Front Speakers Replacement: adım 3, 1 resimden 1.
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Front Speakers Replacement: adım 4, 3 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 4, 3 resimden 2. Monster Soundstage S2 Front Speakers Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Front Speakers Replacement: adım 5, 2 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 5, 2 resimden 2.
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Front Speakers Replacement: adım 6, 2 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 6, 2 resimden 2.
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Front Speakers Replacement: adım 7, 3 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 7, 3 resimden 2. Monster Soundstage S2 Front Speakers Replacement: adım 7, 3 resimden 3.
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Front Speakers Replacement: adım 8, 1 resimden 1.
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Front Speakers Replacement, Front Speakers: adım 9, 3 resimden 1. Monster Soundstage S2 Front Speakers Replacement, Front Speakers: adım 9, 3 resimden 2. Monster Soundstage S2 Front Speakers Replacement, Front Speakers: adım 9, 3 resimden 3.
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Front Speakers Replacement: adım 10, 2 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 10, 2 resimden 2.
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Front Speakers Replacement: adım 11, 3 resimden 1. Monster Soundstage S2 Front Speakers Replacement: adım 11, 3 resimden 2. Monster Soundstage S2 Front Speakers Replacement: adım 11, 3 resimden 3.
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josue A Melgar
116 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 21-5, Maness Winter 2017 Cal Poly, Team 21-5, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G5
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Does anybody know what size driver the rear woofer is and resistance, would like to repair an s3 for a friend in cuba who received a used one as a gift
Matt Gould - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 29
Her zaman: 394
