Ana içeriğe geç
Moto Z Speaker Replacement
Neye ihtiyacın var
  1. Moto Z Speaker Replacement, Display Assembly: adım 1, 1 resimden 1.
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
    FixBot'a Sor
    Yorum Ekle
  2. Moto Z Speaker Replacement: adım 2, 2 resimden 1. Moto Z Speaker Replacement: adım 2, 2 resimden 2.
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
    FixBot'a Sor
    Yorum Ekle
  3. Moto Z Speaker Replacement: adım 3, 3 resimden 1. Moto Z Speaker Replacement: adım 3, 3 resimden 2. Moto Z Speaker Replacement: adım 3, 3 resimden 3.
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
    FixBot'a Sor
    Yorum Ekle
  4. Moto Z Speaker Replacement: adım 4, 3 resimden 1. Moto Z Speaker Replacement: adım 4, 3 resimden 2. Moto Z Speaker Replacement: adım 4, 3 resimden 3.
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  5. Moto Z Speaker Replacement: adım 5, 1 resimden 1.
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Moto Z Speaker Replacement: adım 6, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  7. Moto Z Speaker Replacement: adım 7, 2 resimden 1. Moto Z Speaker Replacement: adım 7, 2 resimden 2.
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  8. Moto Z Speaker Replacement: adım 8, 3 resimden 1. Moto Z Speaker Replacement: adım 8, 3 resimden 2. Moto Z Speaker Replacement: adım 8, 3 resimden 3.
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
    FixBot'a Sor
    Yorum Ekle
  9. Moto Z Speaker Replacement: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
    FixBot'a Sor
    Yorum Ekle
  10. Moto Z Speaker Replacement: adım 10, 3 resimden 1. Moto Z Speaker Replacement: adım 10, 3 resimden 2. Moto Z Speaker Replacement: adım 10, 3 resimden 3.
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
    FixBot'a Sor
    Yorum Ekle
  11. Moto Z Speaker Replacement: adım 11, 2 resimden 1. Moto Z Speaker Replacement: adım 11, 2 resimden 2.
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
    FixBot'a Sor
    Yorum Ekle
  12. Moto Z Speaker Replacement: adım 12, 3 resimden 1. Moto Z Speaker Replacement: adım 12, 3 resimden 2. Moto Z Speaker Replacement: adım 12, 3 resimden 3.
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
    FixBot'a Sor
    Yorum Ekle
  13. Moto Z Speaker Replacement: adım 13, 3 resimden 1. Moto Z Speaker Replacement: adım 13, 3 resimden 2. Moto Z Speaker Replacement: adım 13, 3 resimden 3.
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
    FixBot'a Sor
    Yorum Ekle
  14. Moto Z Speaker Replacement: adım 14, 2 resimden 1. Moto Z Speaker Replacement: adım 14, 2 resimden 2.
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
    FixBot'a Sor
    Yorum Ekle
  15. Moto Z Speaker Replacement: adım 15, 2 resimden 1. Moto Z Speaker Replacement: adım 15, 2 resimden 2.
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
    FixBot'a Sor
    Yorum Ekle
  16. Moto Z Speaker Replacement, Speaker: adım 16, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  17. Moto Z Speaker Replacement: adım 17, 2 resimden 1. Moto Z Speaker Replacement: adım 17, 2 resimden 2.
    • Lift up and remove the speaker with the spudger.
    • It's best to use the blue iFixit opening tool to pry off the speaker. Metal tools can be dangerous.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
2 farklı kişi bu kılavuzu tamamladı.
Miriam Lam
1.188 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G2, Livingston Winter 2018 Cal Poly, Team S2-G2, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G2
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 45
Her zaman: 2,896
