Ana içeriğe geç
Motorola Edge Interconnect Cable Replacement
Neye ihtiyacın var
  1. Motorola  Edge Interconnect Cable Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola  Edge Interconnect Cable Replacement, Separate the bottom adhesive: adım 2, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Separate the bottom adhesive: adım 2, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Separate the bottom adhesive: adım 2, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola  Edge Interconnect Cable Replacement, Slice the bottom adhesive: adım 3, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Slice the bottom adhesive: adım 3, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Slice the bottom adhesive: adım 3, 3 resimden 3.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola  Edge Interconnect Cable Replacement, Heat the right edge: adım 4, 1 resimden 1.
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola  Edge Interconnect Cable Replacement, Separate the corner adhesive: adım 5, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Separate the corner adhesive: adım 5, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Separate the corner adhesive: adım 5, 3 resimden 3.
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola  Edge Interconnect Cable Replacement, Separate the right adhesive: adım 6, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Separate the right adhesive: adım 6, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Separate the right adhesive: adım 6, 3 resimden 3.
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola  Edge Interconnect Cable Replacement, Remove the back cover: adım 7, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Remove the back cover: adım 7, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola  Edge Interconnect Cable Replacement, Remove the motherboard's screws: adım 8, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola  Edge Interconnect Cable Replacement, Remove the motherboard cover: adım 9, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Remove the motherboard cover: adım 9, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Remove the motherboard cover: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  10. Motorola  Edge Interconnect Cable Replacement, Disconnect the battery cable's press connector: adım 10, 2 resimden 1. Motorola  Edge Interconnect Cable Replacement, Disconnect the battery cable's press connector: adım 10, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard's t5 screws: adım 11, 2 resimden 1. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard's t5 screws: adım 11, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  12. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard cover: adım 12, 3 resimden 1. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard cover: adım 12, 3 resimden 2. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard cover: adım 12, 3 resimden 3.
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
  13. Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the motherboard: adım 13, 2 resimden 1. Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the motherboard: adım 13, 2 resimden 2.
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  14. Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the daughterboard: adım 14, 2 resimden 1. Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the daughterboard: adım 14, 2 resimden 2.
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  15. Motorola  Edge Interconnect Cable Replacement, Remove the interconnect cable: adım 15, 2 resimden 1. Motorola  Edge Interconnect Cable Replacement, Remove the interconnect cable: adım 15, 2 resimden 2.
    • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Jennifer Berg
2.867 İtibar
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 305
