Ana içeriğe geç
Motorola Moto E4 Plus Battery Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: adım 1, 3 resimden 1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: adım 1, 3 resimden 2. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Battery Replacement: adım 2, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 2, 2 resimden 2.
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Battery Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Battery Replacement: adım 4, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 4, 2 resimden 2.
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Battery Replacement: adım 5, 3 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 5, 3 resimden 2. Motorola Moto E4 Plus Battery Replacement: adım 5, 3 resimden 3.
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Battery Replacement: adım 6, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Battery Replacement: adım 7, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 7, 2 resimden 2.
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Battery Replacement: adım 8, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 8, 2 resimden 2.
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: adım 9, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: adım 9, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Battery Replacement, Battery: adım 10, 3 resimden 1. Motorola Moto E4 Plus Battery Replacement, Battery: adım 10, 3 resimden 2. Motorola Moto E4 Plus Battery Replacement, Battery: adım 10, 3 resimden 3.
    • Use a pair of tweezers to peel the ends of the two pull tabs off of the bottom edge of the battery.
  11. Motorola Moto E4 Plus Battery Replacement: adım 11, 3 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 11, 3 resimden 2. Motorola Moto E4 Plus Battery Replacement: adım 11, 3 resimden 3.
    • Pull out the left adhesive strip by steadily pulling the left tab at a flat angle.
    • If the adhesive strip rips, grab and twist the remaining stub around the tip of a pair of tweezers a couple of times and then continue pulling.
    • Repeat the same process for the right adhesive strip.
  12. Motorola Moto E4 Plus Battery Replacement: adım 12, 2 resimden 1. Motorola Moto E4 Plus Battery Replacement: adım 12, 2 resimden 2.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape.
    • In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery.
    • Press the new battery firmly into place for 5-10 seconds.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
19 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.936 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.198 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 31
Son 30 gün: 101
Her zaman: 22,355
