Ana içeriğe geç
Motorola Moto E4 Plus Screen Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Plus Screen Replacement, Remove the back cover: adım 1, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement, Remove the back cover: adım 1, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Screen Replacement: adım 2, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 2, 2 resimden 2.
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Screen Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Screen Replacement: adım 4, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 4, 2 resimden 2.
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Screen Replacement: adım 5, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 5, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement: adım 5, 3 resimden 3.
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Screen Replacement: adım 6, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Screen Replacement: adım 7, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 7, 2 resimden 2.
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Screen Replacement: adım 8, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 8, 2 resimden 2.
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Screen Replacement, Battery Disconnect: adım 9, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement, Battery Disconnect: adım 9, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Screen Replacement, Motherboard Assembly: adım 10, 1 resimden 1.
    • Remove the two 2.9 mm Phillips screws.
  11. Motorola Moto E4 Plus Screen Replacement: adım 11, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 11, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement: adım 11, 3 resimden 3.
    • Use the edge of a spudger to pry up the flap of the ZIF connector located below the SIM slot on the left side of the motherboard.
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • To reattach ZIF connectors like this one, carefully insert the flex cable into the ZIF connector up to the marked line on the cable, and then close the locking flap.
  12. Motorola Moto E4 Plus Screen Replacement: adım 12, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
  13. Motorola Moto E4 Plus Screen Replacement: adım 13, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 13, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the interconnect flex cable.
  14. Motorola Moto E4 Plus Screen Replacement: adım 14, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 14, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement: adım 14, 3 resimden 3.
    • Use the tip of a spudger or an opening pick to pry up the flap of the ZIF connector, located in the bottom right corner of the motherboard.
    • Use a pair of tweezers to pull the display flex cable out of the ZIF connector.
  15. Motorola Moto E4 Plus Screen Replacement: adım 15, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 15, 2 resimden 2.
    • Grasp the motherboard by the top corners and remove it by lifting up and pulling it carefully out of its recess.
  16. Motorola Moto E4 Plus Screen Replacement, Earpiece Speaker: adım 16, 1 resimden 1.
    • Apply a heated iOpener to the upper part of the phone for about 30 seconds to loosen the adhesive beneath the earpiece speaker.
  17. Motorola Moto E4 Plus Screen Replacement: adım 17, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 17, 2 resimden 2.
    • When removing the earpiece speaker with a pair of tweezers, take care to grab the whole unit. The earpiece speaker can easily break in two pieces if you only pull on its upper half.
    • Use a pair of tweezers to lift the earpiece speaker out of its recess and remove it.
    • When reassembling, be sure to properly orient the earpiece speaker such that the gold contacts are pointing away from the top edge.
  18. Motorola Moto E4 Plus Screen Replacement, Display with Frame: adım 18, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement, Display with Frame: adım 18, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement, Display with Frame: adım 18, 3 resimden 3.
    • Use a pair of tweezers to gently peel the power and volume button unit out of its thin recess on the left side of the frame.
    • Remove the power and volume button unit.
  19. Motorola Moto E4 Plus Screen Replacement: adım 19, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 19, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement: adım 19, 3 resimden 3.
    • Use a pair of tweezers to peel the ends of the two pull tabs off of the bottom edge of the battery.
  20. Motorola Moto E4 Plus Screen Replacement: adım 20, 3 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 20, 3 resimden 2. Motorola Moto E4 Plus Screen Replacement: adım 20, 3 resimden 3.
    • Pull out the left adhesive strip by steadily pulling the left tab at a flat angle.
    • If the adhesive strip rips, grab and twist the remaining stub around the tip of a pair of tweezers a couple of times and then continue pulling.
    • Repeat the same process for the right adhesive strip.
  21. Motorola Moto E4 Plus Screen Replacement: adım 21, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 21, 2 resimden 2.
    • Get a good grip on the battery and remove it.
  22. Motorola Moto E4 Plus Screen Replacement: adım 22, 1 resimden 1.
    • Remove the single 2.9 mm Phillips screw holding the charging board to the frame.
  23. Motorola Moto E4 Plus Screen Replacement: adım 23, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 23, 2 resimden 2.
    • Use a pair of tweezers to pry up and disconnect the antenna cable and remove it.
  24. Motorola Moto E4 Plus Screen Replacement: adım 24, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 24, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
  25. Motorola Moto E4 Plus Screen Replacement: adım 25, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 25, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  26. Motorola Moto E4 Plus Screen Replacement: adım 26, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 26, 2 resimden 2.
    • Insert the tip of a spudger underneath the bottom edge of the charging board and pry upwards.
    • Remove the charging board.
  27. Motorola Moto E4 Plus Screen Replacement: adım 27, 2 resimden 1. Motorola Moto E4 Plus Screen Replacement: adım 27, 2 resimden 2.
    • Use a pair of tweezers to gently peel the interconnect flex cable from the frame and remove it.
  28. Motorola Moto E4 Plus Screen Replacement: adım 28, 1 resimden 1.
    • The bare screen with frame remains.
    • Before reassembly, check your new part for any components like gaskets, that might need to be transferred from the old one.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.948 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.198 adet Kılavuz yazıldı
2 Yorum
Bonjour cher ami
Grace a vous je me suis lancé dans le remplacement de mon ecran explosé par le passage d’un véhicule. j’ai suivi vos explications a la lettre dans le démontage et pour le remontage aussi vous n’avez pas signalé de récupérer le revêtement de cuivre, j’ai réussi de le décoller en chauffant. Tout fonctionne comme avant.
Merci de ce tuto. Félicitations.
henri perrin - Yanıt
Thanks for your comment. Glad to hear you could get it back to working conditions. Welcome to the club of fixers.
Tobias Isakeit -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 39
Her zaman: 5,489
