Giriş
Replace a cracked rear glass panel on your Motorola Moto G6, or remove it for further disassembly.
Neye ihtiyacın var
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G6 Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Hi William,
How would I put a new cover back on? Does it require new adhesive?
Hi Brendan,
You do not need a new adhesive. Simply place the back shell on the device, and apply pressure on all sides to seal it.
My Moto G6 has a back that is glass, which is now shattered, where can I get a replacement?
my back says it cant be removed, what do i do
