Ana içeriğe geç
Nexus 5X Battery Replacement
Neye ihtiyacın var
  1. Nexus 5X Battery Replacement, SIM Card Tray: adım 1, 3 resimden 1. Nexus 5X Battery Replacement, SIM Card Tray: adım 1, 3 resimden 2. Nexus 5X Battery Replacement, SIM Card Tray: adım 1, 3 resimden 3.
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Battery Replacement, Rear Panel: adım 2, 3 resimden 1. Nexus 5X Battery Replacement, Rear Panel: adım 2, 3 resimden 2. Nexus 5X Battery Replacement, Rear Panel: adım 2, 3 resimden 3.
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Battery Replacement: adım 3, 3 resimden 1. Nexus 5X Battery Replacement: adım 3, 3 resimden 2. Nexus 5X Battery Replacement: adım 3, 3 resimden 3.
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Battery Replacement: adım 4, 2 resimden 1. Nexus 5X Battery Replacement: adım 4, 2 resimden 2.
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Battery Replacement, Midframe: adım 5, 1 resimden 1.
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  6. Nexus 5X Battery Replacement: adım 6, 2 resimden 1. Nexus 5X Battery Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  7. Nexus 5X Battery Replacement: adım 7, 2 resimden 1. Nexus 5X Battery Replacement: adım 7, 2 resimden 2.
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Battery Replacement: adım 8, 2 resimden 1. Nexus 5X Battery Replacement: adım 8, 2 resimden 2.
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Battery Replacement: adım 9, 2 resimden 1. Nexus 5X Battery Replacement: adım 9, 2 resimden 2.
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Battery Replacement, Battery Disconnect: adım 10, 2 resimden 1. Nexus 5X Battery Replacement, Battery Disconnect: adım 10, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Battery Replacement, Battery: adım 11, 1 resimden 1.
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the back of the phone for at least two minutes.
  12. Nexus 5X Battery Replacement: adım 12, 2 resimden 1. Nexus 5X Battery Replacement: adım 12, 2 resimden 2.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger under the bottom left corner of the battery and gently pry upwards.
    • The adhesive is only located beneath the edges of the battery so there's no need to pry beneath its center.
    • If you are having trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
  13. Nexus 5X Battery Replacement: adım 13, 2 resimden 1. Nexus 5X Battery Replacement: adım 13, 2 resimden 2.
    • Insert the flat end of a spudger under the bottom right corner of the battery and gently pry upwards to loosen the remaining adhesive.
  14. Nexus 5X Battery Replacement: adım 14, 1 resimden 1.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
122 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
246.494 İtibar
682 adet Kılavuz yazıldı
31Kılavuz Yorumları
I replaced the battery with a stock LG OEM replacement. Now, 1. Lighting bolt indicator doesn't appear. 2. Doesn't read "Charging" or "Charging Rapidly" on the lock screen. 3. I lost rapid charge; it charges slooooowly. Help!
Thom - Yanıt
Is the battery supposed to be one hard piece or is it supposed to be squishy as in bendable?
danchee - Yanıt
I replaced the battery, but I'm still not getting an led or anything on the screen to show it's charging. What else could be the issue?
pocketdrummer - Yanıt
All went smooth here. Pulled the mainboard out and was able to gently pry the battery free without heat. Rapid charging is working fine. I got an LG battery off Amazon. Didn't cost much more than knock-offs.
Andrew Cook - Yanıt
worked great for me, in the end used brute force to get the battery off with a terrifying crack.
Terrence Benade - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 123
Son 30 gün: 550
Her zaman: 142,444
