Nikon D610 Flash Capacitor Replacement
Giriş
1. adıma gitIn this guide you will learn how to properly remove the flash capacitor allowing for an easy replacement.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
After removal of the battery. Pull the battery compartment door away from the lens.
There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
Remove all the screws and the bottom face should pop off easily.
Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
There are screws hidden in three separate spots.
One is under the rubber doors on the left side of the camera. the next one at the eye hole.
The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
