Ana içeriğe geç
Nikon D610 Flash Capacitor Replacement
Daniel Eagan
Daniel Eagan ve 2 diğer katkıda bulunanlar
En son May 10, 2016 tarihinde güncellendi
45 dakika - 1 saat
Orta
Hatalı İşaretlenmiş
In this guide you will learn how to properly remove the flash capacitor allowing for an easy replacement.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nikon D610 Flash Capacitor Replacement, Battery: adım 1, 1 resimden 1.
    • First, power off the device.
  2. Nikon D610 Flash Capacitor Replacement: adım 2, 3 resimden 1. Nikon D610 Flash Capacitor Replacement: adım 2, 3 resimden 2. Nikon D610 Flash Capacitor Replacement: adım 2, 3 resimden 3.
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Flash Capacitor Replacement: adım 3, 2 resimden 1. Nikon D610 Flash Capacitor Replacement: adım 3, 2 resimden 2.
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
  4. Nikon D610 Flash Capacitor Replacement, Outer Case: adım 4, 1 resimden 1.
    • After removal of the battery. Pull the battery compartment door away from the lens.
    • There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
    • Remove all the screws and the bottom face should pop off easily.
  5. Nikon D610 Flash Capacitor Replacement: adım 5, 3 resimden 1. Nikon D610 Flash Capacitor Replacement: adım 5, 3 resimden 2. Nikon D610 Flash Capacitor Replacement: adım 5, 3 resimden 3.
    • Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
    • There are screws hidden in three separate spots.
    • One is under the rubber doors on the left side of the camera. the next one at the eye hole.
    • The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
    • Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
  6. Nikon D610 Flash Capacitor Replacement: adım 6, 2 resimden 1. Nikon D610 Flash Capacitor Replacement: adım 6, 2 resimden 2.
    • The rear face plate will include the LCD display it separates from the body of the camera with a small tug.
    • Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
    • Once there is enough space it will be possible to gently pull the ribbon cable out of their ports.
  7. Nikon D610 Flash Capacitor Replacement: adım 7, 2 resimden 1. Nikon D610 Flash Capacitor Replacement: adım 7, 2 resimden 2.
    • The next piece to come off is the front plate and the red grip.
    • The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
    • Remove the two Phillips #00 screws holding on the grip and it slides off easily.
    • After removing the screws the face plate comes off by pulling it straight off to avoid damage.
  8. Nikon D610 Flash Capacitor Replacement: adım 8, 2 resimden 1. Nikon D610 Flash Capacitor Replacement: adım 8, 2 resimden 2.
    • It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
    • The screws come out and the cover comes straight off.
    • The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
    • The top should be pulled off very slowly. There are several electronic components that connect between the body and the top.
    • There are three wires that need to be disconnected.
  9. Nikon D610 Flash Capacitor Replacement, Flash Capacitor: adım 9, 2 resimden 1. Nikon D610 Flash Capacitor Replacement, Flash Capacitor: adım 9, 2 resimden 2.
    • The flash capacitor will be to the right of the lens on the front of the camera.
    • There is only one connection that the flash capacitor makes but this was detached earlier.
    • The pictures shown for the flash capacitor removal is from a complete tear down.
  10. Nikon D610 Flash Capacitor Replacement: adım 10, 1 resimden 1.
    • If your flash capacitor looks damaged you can create a discharge tool with this guide. Constructing a Capacitor Discharge Tool
    • Then use the plastic opening tool to pry from underneath the capacitor from top to bottom in order to remove it.
    • Please note that there is glue holding the capacitor to the frame so it will need some coaxing to get it off.
Sonuç
Daniel Eagan
606 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Lacy Spring 2016 USF Tampa, Team 4-4, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,356
