Ana içeriğe geç
Nikon D7000 Mirror Box & Viewfinder Replacement
Thomas Willson
Thomas Willson ve 3 diğer katkıda bulunanlar
En son June 21, 2024 tarihinde güncellendi
1 - 2 saat
Zor
Dilim ve Zar
Use this guide to replace the mirror box and viewfinder.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nikon D7000 Mirror Box & Viewfinder Replacement, Motherboard: adım 1, 1 resimden 1.
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 2, 1 resimden 1.
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 3, 2 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 3, 2 resimden 2.
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 4, 1 resimden 1.
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 6, 1 resimden 1.
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 7, 1 resimden 1.
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 8, 1 resimden 1.
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 9, 1 resimden 1.
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 10, 1 resimden 1.
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 11, 1 resimden 1.
    • Gently pull the SD card cover off.
  12. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 12, 1 resimden 1.
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 13, 1 resimden 1.
    • Carefully lift the back case off.
  14. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 14, 3 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 14, 3 resimden 2. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 14, 3 resimden 3.
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 15, 2 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 15, 2 resimden 2.
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 16, 1 resimden 1.
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 17, 1 resimden 1.
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 18, 1 resimden 1.
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 19, 3 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 19, 3 resimden 2. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 19, 3 resimden 3.
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 20, 2 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 20, 2 resimden 2.
  21. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 21, 1 resimden 1.
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 22, 1 resimden 1.
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 23, 1 resimden 1.
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 24, 1 resimden 1.
    • Lift the motherboard off.
  25. Nikon D7000 Mirror Box & Viewfinder Replacement, Tripod Plate: adım 25, 1 resimden 1.
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 26, 1 resimden 1.
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: adım 27, 2 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: adım 27, 2 resimden 2.
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 28, 1 resimden 1.
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 29, 1 resimden 1.
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Mirror Box & Viewfinder Replacement, Shutter Assembly: adım 30, 1 resimden 1.
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 31, 1 resimden 1.
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 32, 1 resimden 1.
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 33, 2 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 33, 2 resimden 2.
    • Remove the front cover.
  34. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 34, 1 resimden 1.
    • Carefully remove the port cover.
  35. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 35, 1 resimden 1.
    • Deroute the microphone cable.
  36. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 36, 1 resimden 1.
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 37, 1 resimden 1.
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 38, 1 resimden 1.
    • Remove the grip carefully.
  39. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 39, 1 resimden 1.
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 40, 1 resimden 1.
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 41, 1 resimden 1.
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 42, 1 resimden 1.
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 43, 1 resimden 1.
    • Remove the top case.
  44. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 44, 1 resimden 1.
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 45, 3 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 45, 3 resimden 2. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 45, 3 resimden 3.
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 46, 1 resimden 1.
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 47, 1 resimden 1.
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 48, 1 resimden 1.
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 49, 1 resimden 1.
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 50, 1 resimden 1.
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 51, 1 resimden 1.
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 52, 2 resimden 1. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 52, 2 resimden 2.
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 53, 1 resimden 1.
    • Remove all three wire connectors.
  54. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 54, 1 resimden 1.
    • Separate the shutter assembly from the camera body.
  55. Nikon D7000 Mirror Box & Viewfinder Replacement, Mirror Box & Viewfinder: adım 55, 1 resimden 1.
    • Pull out ribbon cable from circuit asembly near front left of device.
  56. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 56, 1 resimden 1.
    • Desolder red & black power leads.
    • Check out our soldering guide for help!
  57. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 57, 1 resimden 1.
    • Disconnect ribbon cable at the top right of camera.
  58. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 58, 1 resimden 1.
    • Disconnect ribbon cable at top right of camera.
  59. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 59, 1 resimden 1.
    • Disconnected ribbon cable at rear right of viewfinder.
  60. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 60, 1 resimden 1.
    • Remove the two 5.5mm J000 screws
  61. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 61, 1 resimden 1.
    • Remove the 5.5 mm J000 screw.
  62. Nikon D7000 Mirror Box & Viewfinder Replacement: adım 62, 1 resimden 1.
    • Remove the viewfinder from the mirror box assembly.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Thomas Willson
450 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G6
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
now I know why my camera failed,, the motor overheated
sir francis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 85
Her zaman: 12,725
