Ana içeriğe geç
Nintendo GameCube Controller Rumble Motor Replacement
Neye ihtiyacın var
  1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Rumble Motor Replacement: adım 2, 1 resimden 1.
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: adım 3, 2 resimden 1. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: adım 3, 2 resimden 2.
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: adım 4, 1 resimden 1.
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Rumble Motor Replacement: adım 5, 1 resimden 1.
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: adım 6, 2 resimden 1. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: adım 6, 2 resimden 2.
    • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
    • Repeat for the second lead and wire.
    • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
    • For more information, please refer to this soldering guide.
  7. Nintendo GameCube Controller Rumble Motor Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
  8. Nintendo GameCube Controller Rumble Motor Replacement: adım 8, 1 resimden 1.
    • Lift the motor out of the bracket.
    • Remember to not pull by the wires! This can make your repair a lot more complicated.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sean Michel
2.600 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G44
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 43
Son 30 gün: 203
Her zaman: 16,725
