Ana içeriğe geç
Nintendo GameCube Controller Z Button Replacement
Sean Michel
Sean Michel ve 6 diğer katkıda bulunanlar
En son September 23, 2024 tarihinde güncellendi
1 - 3 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
The Z button is located above the right trigger but functions as a button.
Neye ihtiyacın var
Aletler
  1. Nintendo GameCube Controller Z Button Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Z Button Replacement: adım 2, 1 resimden 1.
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - Yanıt
  3. Nintendo GameCube Controller Z Button Replacement, Z Button: adım 3, 2 resimden 1. Nintendo GameCube Controller Z Button Replacement, Z Button: adım 3, 2 resimden 2.
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sean Michel
2.544 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G44
4 Üyeler
31 adet Kılavuz yazıldı
6 Yorum
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - Yanıt
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
My bad no pic it's a pelican wireless controller
Justin Sebastian -
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - Yanıt
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - Yanıt
Does anyone know where to buy the actual button for the Z button? I can’t seem to find one where the pins are further apart up top and closer together towards the bottom of the button. I only see the opposite.
Haig Karakashian - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 26
Son 30 gün: 98
Her zaman: 19,874
