Ana içeriğe geç
Nintendo GameCube Top Case Replacement
dcarlin
dcarlin ve 22 diğer katkıda bulunanlar
En son January 5, 2024 tarihinde güncellendi
1 - 2 dakika
Çok kolay
Removing the top case will allow you access to the GameCube's internal parts.
  1. Nintendo GameCube Top Case Replacement, Top Case: adım 1, 3 resimden 1. Nintendo GameCube Top Case Replacement, Top Case: adım 1, 3 resimden 2. Nintendo GameCube Top Case Replacement, Top Case: adım 1, 3 resimden 3.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Top Case Replacement: adım 2, 3 resimden 1. Nintendo GameCube Top Case Replacement: adım 2, 3 resimden 2. Nintendo GameCube Top Case Replacement: adım 2, 3 resimden 3.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - Yanıt
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
dcarlin
366 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G2
4 Üyeler
45 adet Kılavuz yazıldı
Bir Yorum
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 51
Son 30 gün: 250
Her zaman: 26,692
