Ana içeriğe geç
Nintendo Switch Bluetooth Antenna Replacement
Neye ihtiyacın var
  1. Nintendo Switch Bluetooth Antenna Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Bluetooth Antenna Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Bluetooth Antenna Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Bluetooth Antenna Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Bluetooth Antenna Replacement: adım 5, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 5, 2 resimden 2.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Bluetooth Antenna Replacement: adım 6, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Bluetooth Antenna Replacement: adım 7, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Bluetooth Antenna Replacement: adım 8, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 8, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Bluetooth Antenna Replacement, Remove the microSD card reader: adım 9, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Bluetooth Antenna Replacement: adım 10, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Bluetooth Antenna Replacement, Remove the shield plate: adım 11, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch Bluetooth Antenna Replacement: adım 12, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 12, 2 resimden 2.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  13. Nintendo Switch Bluetooth Antenna Replacement: adım 13, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 13, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 13, 3 resimden 3.
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  14. Nintendo Switch Bluetooth Antenna Replacement, Disconnect the battery: adım 14, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  15. Nintendo Switch Bluetooth Antenna Replacement, Remove the heat sink: adım 15, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  16. Nintendo Switch Bluetooth Antenna Replacement: adım 17, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 17, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 17, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
  17. Nintendo Switch Bluetooth Antenna Replacement, Remove the headphone jack and game card reader: adım 18, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Remove the headphone jack and game card reader: adım 18, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  18. Nintendo Switch Bluetooth Antenna Replacement: adım 19, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 19, 2 resimden 2.
    • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
    • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
    • With the cable parallel to the board, gently slide it into its connector.
    • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
    • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
  19. Nintendo Switch Bluetooth Antenna Replacement: adım 20, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 20, 2 resimden 2.
    • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
  20. Nintendo Switch Bluetooth Antenna Replacement: adım 21, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
  21. Nintendo Switch Bluetooth Antenna Replacement: adım 22, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
  22. Nintendo Switch Bluetooth Antenna Replacement: adım 23, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 23, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
  23. Nintendo Switch Bluetooth Antenna Replacement, Remove the motherboard: adım 24, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Remove the motherboard: adım 24, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
  24. Nintendo Switch Bluetooth Antenna Replacement: adım 25, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
  25. Nintendo Switch Bluetooth Antenna Replacement: adım 26, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 26, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
  26. Nintendo Switch Bluetooth Antenna Replacement: adım 27, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 27, 2 resimden 2.
    • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
  27. Nintendo Switch Bluetooth Antenna Replacement: adım 28, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 28, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power and volume button ribbon cable ZIF connector.
  28. Nintendo Switch Bluetooth Antenna Replacement: adım 29, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 29, 2 resimden 2.
  29. Nintendo Switch Bluetooth Antenna Replacement: adım 30, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 30, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
  30. Nintendo Switch Bluetooth Antenna Replacement: adım 31, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 31, 2 resimden 2.
  31. Nintendo Switch Bluetooth Antenna Replacement: adım 32, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 32, 2 resimden 2.
    • Use the point of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail's data cable ZIF connector.
  32. Nintendo Switch Bluetooth Antenna Replacement: adım 33, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 33, 2 resimden 2.
  33. Nintendo Switch Bluetooth Antenna Replacement: adım 34, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 34, 2 resimden 2.
    • Use the point of a spudger to pry up the black antenna cable straight up out of its socket on the motherboard.
  34. Nintendo Switch Bluetooth Antenna Replacement: adım 35, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 35, 2 resimden 2.
    • Use the point of a spudger to pry up the white antenna cable straight up out of its socket on the motherboard.
  35. Nintendo Switch Bluetooth Antenna Replacement: adım 36, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 36, 2 resimden 2.
    • Use your fingers or a pair of tweezers to pull the right speaker connector straight out of its socket on the motherboard.
    • Do not pull on the connector by the speaker wires. They're very thin and can easily snap off the connector.
  36. Nintendo Switch Bluetooth Antenna Replacement: adım 37, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 37, 2 resimden 2.
    • Use your fingers or a pair of tweezers to pull the left speaker connector straight out of its socket on the motherboard.
  37. Nintendo Switch Bluetooth Antenna Replacement: adım 38, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 38, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail data cable ZIF connector.
  38. Nintendo Switch Bluetooth Antenna Replacement: adım 39, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 39, 2 resimden 2.
    • Use a pair of tweezers to slide the Joy Con rail data cable straight out of its connector on the motherboard.
  39. Nintendo Switch Bluetooth Antenna Replacement: adım 40, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the following screws:
    • Four 2.5 mm screws
    • Two 3.1 mm screws
  40. Nintendo Switch Bluetooth Antenna Replacement: adım 41, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 41, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 41, 3 resimden 3.
    • Insert a spudger into a gap between the motherboard and the frame.
    • Carefully lift up the motherboard and remove it from the frame.
  41. Nintendo Switch Bluetooth Antenna Replacement, Remove the Fan: adım 42, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 4.8 mm screws securing the fan.
  42. Nintendo Switch Bluetooth Antenna Replacement: adım 43, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 43, 2 resimden 2.
    • Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the rubber bushings) to the new part before installing.
  43. Nintendo Switch Bluetooth Antenna Replacement, Remove the Right Joy Con Sensor Rail: adım 44, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the four 3.7 mm screws securing the right Joy Con rail to the frame of the device.
    • These screws are torqued down and can be difficult to remove. To prevent them from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  44. Nintendo Switch Bluetooth Antenna Replacement: adım 45, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 45, 2 resimden 2.
    • Remove the right Joy Con sensor rail.
    • Take care not to snag the rail's data cable on the device frame as you remove it.
  45. Nintendo Switch Bluetooth Antenna Replacement, Remove the Left Joy Con Sensor Rail: adım 46, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Remove the Left Joy Con Sensor Rail: adım 46, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the battery connector up and out of the way of the Joy Con rail's data cable.
  46. Nintendo Switch Bluetooth Antenna Replacement: adım 47, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 47, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 47, 3 resimden 3.
  47. Nintendo Switch Bluetooth Antenna Replacement: adım 48, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the four 3.7 mm screws securing the left Joy Con rail to the frame of the device.
  48. Nintendo Switch Bluetooth Antenna Replacement: adım 49, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 49, 2 resimden 2.
    • Remove the left Joy Con sensor rail from the device.
  49. Nintendo Switch Bluetooth Antenna Replacement, Remove the Power and Volume Button Board: adım 50, 1 resimden 1.
    • Use the flat end of a spudger to pry up the taped down power/volume ribbon cable.
  50. Nintendo Switch Bluetooth Antenna Replacement: adım 51, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 51, 2 resimden 2.
    • Remove the power/volume board with a pair of blunt nose tweezers.
  51. Nintendo Switch Bluetooth Antenna Replacement, Remove the Exterior Power and Volume Buttons: adım 52, 1 resimden 1.
    • Pull the rubber conductive pad out with a pair of blunt nose tweezers.
  52. Nintendo Switch Bluetooth Antenna Replacement: adım 53, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 53, 2 resimden 2.
    • Pull the power and volume buttons out with a pair of blunt nose tweezers.
  53. Nintendo Switch Bluetooth Antenna Replacement, Remove the WiFi Antenna: adım 54, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement, Remove the WiFi Antenna: adım 54, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement, Remove the WiFi Antenna: adım 54, 3 resimden 3.
    • Deroute the black coax cable from the midframe.
  54. Nintendo Switch Bluetooth Antenna Replacement: adım 55, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 55, 2 resimden 2.
    • Continue following the wire, derouting it as you go.
  55. Nintendo Switch Bluetooth Antenna Replacement: adım 56, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 56, 2 resimden 2.
    • Pry the metal barrel surrounding the coax up from the midframe.
  56. Nintendo Switch Bluetooth Antenna Replacement: adım 57, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 57, 2 resimden 2.
    • Grasp the WiFi antenna board with a pair of tweezers and lift straight up to remove it.
  57. Nintendo Switch Bluetooth Antenna Replacement, Remove the Screen: adım 58, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  58. Nintendo Switch Bluetooth Antenna Replacement: adım 59, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 59, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 59, 3 resimden 3.
    • Apply a suction cup to the bottom-left corner of the screen.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
  59. Nintendo Switch Bluetooth Antenna Replacement: adım 60, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 60, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 60, 3 resimden 3.
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
  60. Nintendo Switch Bluetooth Antenna Replacement: adım 61, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 61, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 61, 3 resimden 3.
    • Insert a second opening pick into the gap to the left of the first pick.
    • Slide the opening pick back towards the left side of the device.
    • Leave the opening pick inserted.
  61. Nintendo Switch Bluetooth Antenna Replacement: adım 62, 1 resimden 1.
    • Heat the left edge of the screen for around two minutes to help soften the adhesive.
  62. Nintendo Switch Bluetooth Antenna Replacement: adım 63, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 63, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 63, 3 resimden 3.
    • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
  63. Nintendo Switch Bluetooth Antenna Replacement: adım 64, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 64, 2 resimden 2.
    • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
  64. Nintendo Switch Bluetooth Antenna Replacement: adım 65, 1 resimden 1.
    • Heat the top edge of the screen for around two minutes to help soften the adhesive.
  65. Nintendo Switch Bluetooth Antenna Replacement: adım 66, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 66, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 66, 3 resimden 3.
    • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
  66. Nintendo Switch Bluetooth Antenna Replacement: adım 67, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 67, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 67, 3 resimden 3.
    • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
  67. Nintendo Switch Bluetooth Antenna Replacement: adım 68, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 68, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 68, 3 resimden 3.
    • Heat the right edge of the screen for around two minutes to help soften the adhesive.
    • Place the flat end of a spudger into the gap along the left edge of the screen.
    • Carefully and slowly lift the left edge of the screen, opening it like a book.
  68. Nintendo Switch Bluetooth Antenna Replacement: adım 69, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 69, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 69, 3 resimden 3.
    • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
  69. Nintendo Switch Bluetooth Antenna Replacement, Remove the Front Frame: adım 70, 1 resimden 1.
    • Remove the four screws securing the front frame to the midframe.
  70. Nintendo Switch Bluetooth Antenna Replacement: adım 71, 3 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 71, 3 resimden 2. Nintendo Switch Bluetooth Antenna Replacement: adım 71, 3 resimden 3.
    • Lift the front edge of the frame then slide the frame up toward the top of the display to remove it.
  71. Nintendo Switch Bluetooth Antenna Replacement, Remove the Bluetooth Antenna: adım 72, 1 resimden 1.
    • Verify the coax wire is free of any obstructions or routing inside the device.
  72. Nintendo Switch Bluetooth Antenna Replacement: adım 73, 2 resimden 1. Nintendo Switch Bluetooth Antenna Replacement: adım 73, 2 resimden 2.
    • The antenna is held in with light adhesive, so simply grasp it and pull up to release it.
  73. Nintendo Switch Bluetooth Antenna Replacement: adım 74, 1 resimden 1.
    • Pull the coax cable through the slot in the frame.
    • Replacement antennas may not come with the black plastic support piece, so you might have to transfer it from the old antenna to the new one.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jerry Wheeler
72.386 İtibar
71 adet Kılavuz yazıldı
Ekip
Oregonians Oregonians üyesi
Community
8 Üyeler
191 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 115
Son 30 gün: 595
Her zaman: 13,605
