Ana içeriğe geç
Nintendo Switch Exterior Power and Volume Button Replacement
Neye ihtiyacın var
  1. Nintendo Switch Exterior Power and Volume Button Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch Exterior Power and Volume Button Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $16.96
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
  4. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
  5. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the center side screws: adım 5, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the center side screws: adım 5, 2 resimden 2.
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Exterior Power and Volume Button Replacement: adım 6, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the kickstand well screw: adım 7, 1 resimden 1.
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the rear panel: adım 8, 3 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the rear panel: adım 8, 3 resimden 2. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the rear panel: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the shield plate: adım 9, 1 resimden 1.
    • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
  10. Nintendo Switch Exterior Power and Volume Button Replacement: adım 10, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  11. Nintendo Switch Exterior Power and Volume Button Replacement: adım 11, 3 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 11, 3 resimden 2. Nintendo Switch Exterior Power and Volume Button Replacement: adım 11, 3 resimden 3.
    iFixit Thermal Putty
    $9.95
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
  12. Nintendo Switch Exterior Power and Volume Button Replacement, Disconnect the battery: adım 12, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Disconnect the battery: adım 12, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  13. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the heat sink: adım 13, 1 resimden 1.
    • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  14. Nintendo Switch Exterior Power and Volume Button Replacement: adım 15, 3 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 15, 3 resimden 2. Nintendo Switch Exterior Power and Volume Button Replacement: adım 15, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
  15. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the fan: adım 16, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the fan: adım 16, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
  16. Nintendo Switch Exterior Power and Volume Button Replacement: adım 17, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 17, 2 resimden 2.
    • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
  17. Nintendo Switch Exterior Power and Volume Button Replacement: adım 18, 1 resimden 1.
    • Use a JIS 00 driver to remove the three 4.8 mm screws securing the fan.
  18. Nintendo Switch Exterior Power and Volume Button Replacement: adım 19, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 19, 2 resimden 2.
    • Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the rubber bushings) to the new part before installing.
  19. Nintendo Switch Exterior Power and Volume Button Replacement, Power and Volume Button Board: adım 20, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement, Power and Volume Button Board: adım 20, 2 resimden 2.
    • Use a spudger to flip up the small black locking flap on the power/volume ribbon cable ZIF connector.
  20. Nintendo Switch Exterior Power and Volume Button Replacement: adım 21, 1 resimden 1.
    • Use the flat end of a spudger to pry up the taped down power/volume ribbon cable.
  21. Nintendo Switch Exterior Power and Volume Button Replacement: adım 22, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 22, 2 resimden 2.
  22. Nintendo Switch Exterior Power and Volume Button Replacement, Exterior Power and Volume Buttons: adım 23, 1 resimden 1.
    • Pull the rubber conductive pad out with a pair of blunt nose tweezers.
  23. Nintendo Switch Exterior Power and Volume Button Replacement: adım 24, 2 resimden 1. Nintendo Switch Exterior Power and Volume Button Replacement: adım 24, 2 resimden 2.
    • Pull the power and volume buttons out with a pair of blunt nose tweezers.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Blake Klein
73.721 İtibar
50 adet Kılavuz yazıldı
3Kılavuz Yorumları
What happens if the small black locking flap breaks?
James Funderburk - Yanıt
Two angles are congruent if they have the same measure. You already know that when two lines intersect the vertical angles formed are congruent. You have also seen that if ∠A and ∠B are each complementary to ∠C, then ∠A ~= ∠B. There are other angle relationships to explore. When you expose these angle relationships, you will establish their truth using a formal proof.
Qui Ma - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 234
Son 30 gün: 969
Her zaman: 16,976
