Ana içeriğe geç
Nintendo Switch Headphone Jack and Game Card Board Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Nintendo Switch Headphone Jack and Game Card Board Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch Headphone Jack and Game Card Board Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 5, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 5, 2 resimden 2.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 6, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 7, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 8, 3 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 8, 3 resimden 2. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the microSD card reader: adım 9, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 10, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the shield plate: adım 11, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 12, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 12, 2 resimden 2.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  13. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 13, 3 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 13, 3 resimden 2. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 13, 3 resimden 3.
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  14. Nintendo Switch Headphone Jack and Game Card Board Replacement, Disconnect the battery: adım 14, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  15. Nintendo Switch Headphone Jack and Game Card Board Replacement, Remove the heat sink: adım 15, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  16. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 17, 3 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 17, 3 resimden 2. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 17, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
  17. Nintendo Switch Headphone Jack and Game Card Board Replacement, Headphone Jack and Game Card Board: adım 18, 1 resimden 1.
    • Remove the two 3.1 mm Phillips screws from the headphone jack bracket.
  18. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 19, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 19, 2 resimden 2.
    • Remove the headphone jack bracket.
  19. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 20, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 20, 2 resimden 2.
    • Use a spudger to lift the black locking flap on the ZIF connector up.
    • To reconnect ZIF connectors like this one, gently slide the cable back in place and press the locking flap back into place.
  20. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 21, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 21, 2 resimden 2.
    • Use the pointed end of a spudger to slide the ribbon cable out of the ZIF connector.
  21. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 22, 1 resimden 1.
    • Remove the single 3.1 mm Phillips screw from the headphone jack and game card board.
  22. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 23, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 23, 2 resimden 2.
    • Use the flat end of a spudger to pry the headphone jack press-fit connector straight up off the motherboard.
  23. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 24, 2 resimden 1. Nintendo Switch Headphone Jack and Game Card Board Replacement: adım 24, 2 resimden 2.
    • Remove the headphone jack and game card board.
Sonuç
Blake Klein
72.384 İtibar
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 45
