Ana içeriğe geç
Nintendo Switch Micro SD Card Reader Replacement
Neye ihtiyacın var
  1. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    FixBot'a Sor
  2. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    FixBot'a Sor
  3. Nintendo Switch Micro SD Card Reader Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    FixBot'a Sor
  4. Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    FixBot'a Sor
  5. Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: adım 5, 2 resimden 1. Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: adım 5, 2 resimden 2.
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    FixBot'a Sor
  6. Nintendo Switch Micro SD Card Reader Replacement: adım 6, 2 resimden 1. Nintendo Switch Micro SD Card Reader Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    FixBot'a Sor
  7. Nintendo Switch Micro SD Card Reader Replacement, Remove the kickstand well screw: adım 7, 1 resimden 1.
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    FixBot'a Sor
  8. Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: adım 8, 3 resimden 1. Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: adım 8, 3 resimden 2. Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    FixBot'a Sor
  9. Nintendo Switch Micro SD Card Reader Replacement, Remove the microSD card reader: adım 9, 1 resimden 1.
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    FixBot'a Sor
  10. Nintendo Switch Micro SD Card Reader Replacement: adım 10, 2 resimden 1. Nintendo Switch Micro SD Card Reader Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
    FixBot'a Sor
Sonuç
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
177 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
42.725 İtibar
82 adet Kılavuz yazıldı
65Kılavuz Yorumları
My SD reader never worked.
Used this guide to find that it was never seated correctly. Reseated and now works perfectly. THANK YOU!
Finx O'Mally - Yanıt Paylaş
My console won’t boot if I have an SD card inserted after reseating it. What should I do?
Ewan MacInnis - Yanıt Paylaş
Dont. Just dont
Martin Vincent (i forgo) - Yanıt Paylaş
Easy guide, fixed my problem. Changed the SD card reader cause I was abusing of it by putting SD in and out constantly.
Nicola Bonardi - Yanıt Paylaş
Great guide! My 11-year-old son was able to fix his Switch himself with no difficulty.
Matt - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 70
Son 7 gün: 407
Son 30 gün: 1,953
Her zaman: 275,161
