Giriş
Use this guide to replace the motherboard (with an added right Joy-Con sensor rail removal) in your Nintendo Switch.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Neye ihtiyacın var
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
Use your finger to flip up the kickstand on the back of the device.
Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
Use the flat end of a spudger to separate a corner of the tape from the shield plate.
Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
Use the point of a spudger to pry up and disconnect the battery.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
Insert a spudger between the edge of the daughterboard and the motherboard.
Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
Remove the daughterboard.
Use a Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
Insert a spudger between the heat sink's bracket and the motherboard.
Pry up with the spudger to separate the heat sink from the motherboard.
Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
Use a Phillips driver to remove the three 3 mm screws securing the fan to the frame.
Use a spudger to lift the fan out straight out of the frame.
Remove the fan.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power button board's ZIF connector.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the right Joy-Con sensor rail's ZIF connector.
Use a Phillips driver to remove the two 3.8 mm screws securing the left Joy-Con sensor rail to the frame.
Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
Use tweezers, or your fingers, to pull the left speaker's JST connector out of its socket.
Use tweezers, or your fingers, to pull the right speaker's JST connector out of its socket.
Use a Phillips driver to remove the five screws securing the midframe to the frame:
Three 3 mm screws
Two 4.4 mm screws
Insert a spudger between the motherboard and the frame.
Pry up with the spudger to separate the motherboard from the frame.
Remove the motherboard.
