Ana içeriğe geç
Nintendo Wii Remote Motherboard Replacement
Emily
Emily ve 6 diğer katkıda bulunanlar
En son February 22, 2024 tarihinde güncellendi
10 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
Installing a Wii Remote motherboard requires the removal of the front cover plate and allows access to the B button.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 2.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - Yanıt
  2. Nintendo Wii Remote Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: adım 3, 1 resimden 1.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: adım 4, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement: adım 4, 2 resimden 2.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - Yanıt
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - Yanıt
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: adım 6, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement: adım 6, 2 resimden 2.
    • Grasp the edges of the motherboard and pull it straight away from the case.
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
Emily
1.854 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G44
4 Üyeler
28 adet Kılavuz yazıldı
7Kılavuz Yorumları
Where do you find a motherboard and how much do they typically cost?
Jeff - Yanıt
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Yanıt
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Yanıt
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Yanıt
Just adding a comment to dispute the above suggestion that “this is useless”. I used this guide to help repair a damaged Wii Controller which had had some battery leakage onto the mainboard. I was able to open the controller, clean up (using vinegar and water) the battery corrosion and re-assemble the controller. It works fine again now and I used this guide to find out that there are plastic clips holding the case together.
Sylph Hawkins - Yanıt
I can't sync my Wii balance board. and remote at the same time. when the Wii remotes sync the balance board goes out and vice versa
Geraldine Cartagena - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 52
Son 30 gün: 245
Her zaman: 35,312
