Ana içeriğe geç
Nintendo Wii Remote Sensor Screen Replacement
Emily
Emily ve 5 diğer katkıda bulunanlar
En son August 13, 2024 tarihinde güncellendi
10 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
These instructions are for an original Nintendo Wii remote, model number RVL-003, also called Wiimote. Nintendo Wii Remote users who have problems controlling the movement of the controller and/or connecting to the sensor bar can fix the issue by replacing the sensor screen within the remote.
Users should first look for dust blocking the LED lens or inspect the remote for other signs of corrosion or deterioration, check the battery, recalibrate the remote, and make sure the sensor bar is connected and not being blocked. If all checks out, it is possible that the sensor screen may need to be replaced.
Inside the Wii remote are built in optics that mimic a camera that connects to the sensor bar’s infrared LED. In addition, the remote contains a silicone anchor that controls the movement of tiny chips that are called accelerometers. Moving the remote up, down, and side to side move the accelerometers inside, which result in movement on the game screen. The remote also contains a stable Bluetooth chip that communicates with the console.
Replacing the sensor requires the user the obtain a new sensor screen part. Wii remote parts may be found on eBay.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 2.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - Yanıt
  2. Nintendo Wii Remote Sensor Screen Replacement: adım 2, 1 resimden 1.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Sensor Screen Replacement: adım 3, 1 resimden 1.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Sensor Screen Replacement: adım 4, 2 resimden 1. Nintendo Wii Remote Sensor Screen Replacement: adım 4, 2 resimden 2.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - Yanıt
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - Yanıt
  5. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: adım 5, 3 resimden 1. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: adım 5, 3 resimden 2. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: adım 5, 3 resimden 3.
    • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
    • Grip the outward edge of the screen with your fingers.
    • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Emily
1.854 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G44
4 Üyeler
28 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can the screen be purchased??
cutsiepie6480 - Yanıt
how is this moderate difficulty
Sqwerks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 74
Son 30 gün: 260
Her zaman: 23,417
