Ana içeriğe geç
Nokia 2630b Screen / Front Case Replacement
Eric
Eric ve 12 diğer katkıda bulunanlar
En son April 18, 2025 tarihinde güncellendi
5 dakika
Kolay
Daha İyi Resimler Gerekli
Öğrenci İş Başında
Madde imleri!
Metin kafa karıştırıcı
Hatalı İşaretlenmiş
Eksik Adımlar
Dilim ve Zar
In this guide, we outline how to unscrew and remove the front case from the Nokia 2630b. This grants access to the LCD screen cover and the keyboard.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nokia 2630b Screen / Front Case Replacement, Battery Case: adım 1, 2 resimden 1. Nokia 2630b Screen / Front Case Replacement, Battery Case: adım 1, 2 resimden 2.
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Screen / Front Case Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Screen / Front Case Replacement, Screen / Front Case: adım 3, 1 resimden 1.
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Screen / Front Case Replacement: adım 4, 3 resimden 1. Nokia 2630b Screen / Front Case Replacement: adım 4, 3 resimden 2. Nokia 2630b Screen / Front Case Replacement: adım 4, 3 resimden 3.
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Screen / Front Case Replacement: adım 5, 1 resimden 1.
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Screen / Front Case Replacement: adım 6, 1 resimden 1.
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Screen / Front Case Replacement: adım 7, 1 resimden 1.
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Screen / Front Case Replacement: adım 8, 2 resimden 1. Nokia 2630b Screen / Front Case Replacement: adım 8, 2 resimden 2.
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Screen / Front Case Replacement: adım 9, 1 resimden 1.
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Screen / Front Case Replacement: adım 10, 2 resimden 1. Nokia 2630b Screen / Front Case Replacement: adım 10, 2 resimden 2.
    • Place computer chip and screen back into black case
  11. Nokia 2630b Screen / Front Case Replacement: adım 11, 1 resimden 1.
    • Place black frame back over screen
  12. Nokia 2630b Screen / Front Case Replacement: adım 12, 2 resimden 1. Nokia 2630b Screen / Front Case Replacement: adım 12, 2 resimden 2.
    • Carefully place keypad back in place
  13. Nokia 2630b Screen / Front Case Replacement: adım 13, 2 resimden 1. Nokia 2630b Screen / Front Case Replacement: adım 13, 2 resimden 2.
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Screen / Front Case Replacement: adım 14, 1 resimden 1.
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Screen / Front Case Replacement: adım 15, 1 resimden 1.
    • Slide battery back into place
  16. Nokia 2630b Screen / Front Case Replacement: adım 16, 1 resimden 1.
    • Snap battery cover back into place
Sonuç
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
Eric
51 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-61, Walters Spring 2011 Cal Poly, Team 9-61, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G61
5 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
jfg - Yanıt
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 3,877
