Ana içeriğe geç
Nokia 6 Battery Replacement
Neye ihtiyacın var
  1. Nokia 6 Battery Replacement, Display Assembly: adım 1, 3 resimden 1. Nokia 6 Battery Replacement, Display Assembly: adım 1, 3 resimden 2. Nokia 6 Battery Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Power off your Nokia 6 before beginning disassembly.
    • Insert the SIM card ejection tool into the hole on the left side of the phone.
    • Remove the SIM card and microSD card.
  2. Nokia 6 Battery Replacement: adım 2, 1 resimden 1.
    • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
    • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
  3. Nokia 6 Battery Replacement: adım 3, 1 resimden 1.
    • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
    • To use the heat gun, plug it into an outlet.
    • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
  4. Nokia 6 Battery Replacement: adım 4, 1 resimden 1.
    • Take a Jimmy and slide it under the glass after the adhesive has been softened.
    • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
    • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
    • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
  5. Nokia 6 Battery Replacement: adım 5, 1 resimden 1.
    • Lift the screen off of the phone.
  6. Nokia 6 Battery Replacement: adım 6, 2 resimden 1. Nokia 6 Battery Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
  7. Nokia 6 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the metal bracket with a tweezer.
  8. Nokia 6 Battery Replacement: adım 8, 1 resimden 1.
    • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
    • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
    • Carefully remove the screen from the device.
  9. Nokia 6 Battery Replacement, Home Button Assembly: adım 9, 1 resimden 1.
    • Disconnect the battery connector with a spudger.
  10. Nokia 6 Battery Replacement: adım 10, 2 resimden 1. Nokia 6 Battery Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
    • Use tweezers to remove the bracket.
  11. Nokia 6 Battery Replacement: adım 11, 2 resimden 1. Nokia 6 Battery Replacement: adım 11, 2 resimden 2.
    • Detach the cable with the black nylon spudger.
    • Detach the home button and remove it from the device.
  12. Nokia 6 Battery Replacement, Midframe: adım 12, 1 resimden 1.
    • Remove 18 screws.
    • There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
    • One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
    • The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
  13. Nokia 6 Battery Replacement: adım 13, 2 resimden 1. Nokia 6 Battery Replacement: adım 13, 2 resimden 2.
    • Decouple the midframe with the spudger and remove the midframe from the device.
  14. Nokia 6 Battery Replacement, Battery: adım 14, 1 resimden 1.
    • Turn the midframe around to see the now exposed battery.
  15. Nokia 6 Battery Replacement: adım 15, 2 resimden 1. Nokia 6 Battery Replacement: adım 15, 2 resimden 2.
    • Pull the two adhesive tabs underneath the battery with a tweezer and then your fingers to remove it.
  16. Nokia 6 Battery Replacement: adım 16, 1 resimden 1.
    • Lift the battery from the midframe.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Chrissy Robins
1.567 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G15, Maness Spring 2019 Cal Poly, Team S9-G15, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G15
4 Üyeler
14 adet Kılavuz yazıldı
7Kılavuz Yorumları
Thanks for the instructions. Looks like I could do a lot of things wrong and my screen is cracked. I think I will go buy a new phone as my Nokia is 3 years old now.
Brent Barber - Yanıt
Thank you, but there are errors and omissions in this guide, please be sure to read the comments under each step.
Re-assembly requires you to insert the plastic tabs on the midframe back into their slots on the bottom side of the enclosure.
Tarmo - Yanıt
I am very grateful for your help,now I got it all figured out..I can do it own my own without necessary taking it to the Nokia center right here in Kenya.
Mwendwa Kenny - Yanıt
Battery kaha hothe hai back per yya front mein
Princesses Princesses - Yanıt
Make sure that neither the soundcloud downloader tool nor the cards touch the LCD edge under the glass. This can cause damage to the ribbon cables underneath and make the phone less stable.
Shelton Baum - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 121
Her zaman: 23,975
