Giriş
Follow this guide to remove and replace the screen and digitizer assembly for the OnePlus 3. Use this guide for screens that come pre-mounted on a frame.
Do not use this guide if you are attempting to replace the screen only. If you start by trying to remove the screen itself, you will most likely tear the capacitative button flex cable. You must open the phone from the back and disconnect multiple cables before removing the screen.
This procedure requires significant disassembly, battery replacement, and parts transfer from the old part to the replacement part. The hardest part is getting the frame clips free.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Neye ihtiyacın var
Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
Press firmly to eject the SIM card tray.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Lift the screen up and remove it.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
Bend the connector away from the socket to prevent accidental contact.
Remove the 3 mm Phillips screw securing the cable bracket.
Remove the cable bracket.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the daughterboard, which is located below the battery.
Slide the edge of an opening tool underneath the fingerprint scanner cover near the bottom edge of the frame and pry up.
Remove the fingerprint scanner cover.
Slide the point of a spudger underneath the antenna interconnect cable located at the bottom left corner of the motherboard.
Pry up and disconnect the antenna interconnect cable.
Bu adımda kullanılan alet:Electrical Tape in 6 Assorted Colors$9.99
Use the point of a spudger to pry up and remove the black tape covering the volume buttons on the right edge of the phone.
Repeat the process with the black tape covering the power button on the left edge of the phone.
Bu adımda kullanılan alet:Tesa 61395 Tape$8.95
Use the point of a spudger to pry and loosen the power button from the left edge of the frame.
To reinstall the power button, cut a small piece of adhesive from the pre-cut adhesive card or a roll of Tesa tape, and use it to stick the button back onto the frame.
Bu adımda kullanılan alet:Tweezers$4.99
Squeeze the tweezer tips together and insert the point under one of the earpiece speaker clips.
Pull the tweezer point up slowly to pry the earpiece speaker out of its recess.
Remove the two 1.9 mm Phillips screws holding the frame grounding clips.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
62 farklı kişi bu kılavuzu tamamladı.
47Kılavuz Yorumları
Yeah I've done one of these and am literally about to do the 2nd one. Easy as you like :D
Be sure to purchase the LCD with frame as it's much quicker.
Hi,
May I kindly ask, both oneplus 3 and oneplus 3T are the same screen? I'm about to buy a screen with frame and digitizer, and all sellers name their products "oneplus 3/3T LCD screen".
if the touch still works and it is only the screen to be cracked is there another procedure to follow? Do I need to replace the whole LCD?
