Giriş
Follow this guide to remove and replace the battery for the OnePlus 5. The hardest part is getting the frame clips free. Once that is done, the rest comes out easily.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
What are the reference of the screws ? They are missing in the one I bought !
Hi Yôken,
They help hold the back cover on. Most of the time, the clips are enough to hold the phone together.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket.
Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our OnePlus 5 Answers community for troubleshooting help.
20 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Thanks a lot for your contribution! It worked perfectly.
I follow the instructions but it said the battery is too slow
Charge the battery for at least a few hours. If the battery does not charge, double-check all connectors, especially the interconnect cable. Does the phone react to a charging cable? If not, something may be broken between the USB port and the motherboard.
It honestly took an hour to get the back cover off, and then another hour to take the rest apart and put it back together. But this guide was useful.
Thanks so much for this guide. Worked out great!
Followed the guide and worked perfectly. Thank you!
