Ana içeriğe geç
OnePlus 6T Back Cover Replacement
Neye ihtiyacın var
  1. OnePlus 6T Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    FixBot'a Sor
    Yorum Ekle
  2. OnePlus 6T Back Cover Replacement: adım 2, 1 resimden 1.
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    FixBot'a Sor
    Yorum Ekle
  3. OnePlus 6T Back Cover Replacement: adım 3, 1 resimden 1.
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. OnePlus 6T Back Cover Replacement: adım 4, 3 resimden 1. OnePlus 6T Back Cover Replacement: adım 4, 3 resimden 2. OnePlus 6T Back Cover Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
I wonder if this is the same for OnePlus 6 (6000/6003)?
karlkristians - Yanıt Paylaş
another greath guide, repaird check.
In same time rplacd the battery so phone is ready for another few years
yoeri - Yanıt Paylaş
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Alexandre Herbreteau - Yanıt Paylaş
Preciso de uma tela para o one plus 6t
Fred Silva - Yanıt Paylaş
Tela one plus 6t quem sabe onde ou se alguém vende
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 112
Her zaman: 21,115
