Giriş
If your OnePlus 6T is experiencing battery drainage issues or won’t hold a charge/won’t charge, then it may be time to replace the phone’s battery.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive in order to complete this repair.
Neye ihtiyacın var
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Bu adımda kullanılan alet:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Bu adımda kullanılan alet:Halberd Spudger$2.99
Using a halberd spudger, gently lift and disconnect the battery connector from the phone.
34 farklı kişi bu kılavuzu tamamladı.
14Kılavuz Yorumları
Does the adhesive for the back cover need to be replaced? Should I heat the phone and back glass for re-assembly?
Good questions. I think “reassembly is the reverse of these instructions" is a bit simplified. I think the heat is only for removal, but perhaps it would cause the adhesive to rebond after reassembly? Can an ifixit tech comment?
Just wondering if anyone can clarify the reattachment of the rear panel, as far as whether it is recommended, or necessary, to heat it again, or get a new adhesive gasket. Thanks.
Good question! You should replace the back cover adhesive with either a custom-cut adhesive or double-sided tape such as Tesa tape. You can choose to reheat and reuse the existing adhesive, but there may be a chance that the back cover will fall off. If you’re reusing adhesive, be sure to remove any uneven adhesive chunks.
What width Tesa tape would work for the replacement of the back cover?
