Ana içeriğe geç
OnePlus Nord Screen Replacement
Neye ihtiyacın var
    1. OnePlus Nord Screen Replacement, Loosen the rear glass adhesive: adım 1, 1 resimden 1.
      • Switch off your phone.
      • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus Nord Screen Replacement, Create a gap: adım 2, 2 resimden 1. OnePlus Nord Screen Replacement, Create a gap: adım 2, 2 resimden 2.
      • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
      • Pull on the suction cup to create a gap between the rear glass and the frame.
      • Insert an opening pick into the gap.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus Nord Screen Replacement, Slice the adhesive: adım 3, 2 resimden 1. OnePlus Nord Screen Replacement, Slice the adhesive: adım 3, 2 resimden 2.
      • Slide the opening pick along the edge to the bottom right corner.
      • Leave the opening pick in its place to prevent the adhesive from resealing.
      • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during this process.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus Nord Screen Replacement: adım 4, 3 resimden 1. OnePlus Nord Screen Replacement: adım 4, 3 resimden 2. OnePlus Nord Screen Replacement: adım 4, 3 resimden 3.
      • Insert a second opening pick under the bottom right corner.
      • Slide the opening pick along the edge to the top right corner.
      • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
      FixBot'a Sor
      Yorum Ekle
    5. OnePlus Nord Screen Replacement: adım 5, 3 resimden 1. OnePlus Nord Screen Replacement: adım 5, 3 resimden 2. OnePlus Nord Screen Replacement: adım 5, 3 resimden 3.
      • Insert a third opening pick under the top right corner of the back cover.
      • Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    6. OnePlus Nord Screen Replacement: adım 6, 3 resimden 1. OnePlus Nord Screen Replacement: adım 6, 3 resimden 2. OnePlus Nord Screen Replacement: adım 6, 3 resimden 3.
      • Insert a fourth opening pick under the top left corner.
      • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
      FixBot'a Sor
      Yorum Ekle
    7. OnePlus Nord Screen Replacement: adım 7, 2 resimden 1. OnePlus Nord Screen Replacement: adım 7, 2 resimden 2.
      • Insert a fifth opening pick under the bottom left corner.
      • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
      FixBot'a Sor
      Yorum Ekle
    8. OnePlus Nord Screen Replacement, Remove the back cover: adım 8, 1 resimden 1.
      • Remove the back cover.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus Nord Screen Replacement, Remove the motherboard cover: adım 9, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the ten 3.6 mm-long screws from the motherboard cover.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus Nord Screen Replacement: adım 10, 3 resimden 1. OnePlus Nord Screen Replacement: adım 10, 3 resimden 2. OnePlus Nord Screen Replacement: adım 10, 3 resimden 3.
      • Insert the tip of an opening pick under the motherboard cover.
      • Use the opening pick to lift the motherboard cover up and release the plastic clips that holds the cover in its place.
      • Remove the motherboard cover.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus Nord Screen Replacement, Disconnect the battery: adım 11, 2 resimden 1. OnePlus Nord Screen Replacement, Disconnect the battery: adım 11, 2 resimden 2.
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      FixBot'a Sor
      Yorum Ekle
    1. OnePlus Nord Screen Replacement, Remove the daughterboard cover: adım 12, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the seven 3.6 mm-long screws.
      FixBot'a Sor
      Yorum Ekle
    2. OnePlus Nord Screen Replacement: adım 13, 3 resimden 1. OnePlus Nord Screen Replacement: adım 13, 3 resimden 2. OnePlus Nord Screen Replacement: adım 13, 3 resimden 3.
      • Insert the tip of an opening pick under the daughterboard cover.
      • Pry up to release the clips holding the daughterboard cover in place.
      • Remove the daughterboard cover.
      FixBot'a Sor
      Yorum Ekle
    3. OnePlus Nord Screen Replacement, Disconnect the display connector: adım 14, 2 resimden 1. OnePlus Nord Screen Replacement, Disconnect the display connector: adım 14, 2 resimden 2.
      • Use the flat edge of a spudger to pry up and disconnect the display connector from its daughterboard socket.
      FixBot'a Sor
      Yorum Ekle
    4. OnePlus Nord Screen Replacement, Apply a heated iOpener: adım 15, 1 resimden 1.
      • Apply a Heat an iOpener to the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      FixBot'a Sor
      Yorum Ekle
    5. OnePlus Nord Screen Replacement, Create a gap: adım 16, 3 resimden 1. OnePlus Nord Screen Replacement, Create a gap: adım 16, 3 resimden 2. OnePlus Nord Screen Replacement, Create a gap: adım 16, 3 resimden 3.
      • Apply a suction cup to the right edge of the display.
      • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull up the suction cup with strong, steady force to create a gap.
      • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
      FixBot'a Sor
      Yorum Ekle
    6. OnePlus Nord Screen Replacement, Slice the adhesive: adım 17, 3 resimden 1. OnePlus Nord Screen Replacement, Slice the adhesive: adım 17, 3 resimden 2. OnePlus Nord Screen Replacement, Slice the adhesive: adım 17, 3 resimden 3.
      • Insert a second opening pick at the bottom right corner.
      • Slide the opening pick along the edge to the top right corner of your phone.
      • Leave both opening picks in their place to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    7. OnePlus Nord Screen Replacement: adım 18, 3 resimden 1. OnePlus Nord Screen Replacement: adım 18, 3 resimden 2. OnePlus Nord Screen Replacement: adım 18, 3 resimden 3.
      • Insert a third opening pick under the top right corner.
      • Slide the opening pick along the edge to slice the adhesive.
      FixBot'a Sor
      Yorum Ekle
    8. OnePlus Nord Screen Replacement: adım 19, 3 resimden 1. OnePlus Nord Screen Replacement: adım 19, 3 resimden 2. OnePlus Nord Screen Replacement: adım 19, 3 resimden 3.
      • Slide the opening pick along the edge to cut the adhesive.
      • Leave the opening pick in the bottom left corner so prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    9. OnePlus Nord Screen Replacement: adım 20, 2 resimden 1. OnePlus Nord Screen Replacement: adım 20, 2 resimden 2.
      • Slide it along the bottom edge to cut the remaining adhesive.
      • Do not remove the screen completely yet. The display cable is still threaded through the frame.
      FixBot'a Sor
      Yorum Ekle
    10. OnePlus Nord Screen Replacement, Remove the display: adım 21, 3 resimden 1. OnePlus Nord Screen Replacement, Remove the display: adım 21, 3 resimden 2. OnePlus Nord Screen Replacement, Remove the display: adım 21, 3 resimden 3.
      • Carefully thread the display cable through the frame.
      • Remove the display.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
35 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
68.008 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
41.952 adet Kılavuz yazıldı
15Kılavuz Yorumları
So essentially the greater part of the guide is only necessary because OnePlus decided to have the display connector at the back of the phone rather than at the front under the display? What a poor choice repairability-wise on their side, very disappointing! Otherwise great guide.
Nikola Steffanov - Yanıt Paylaş
Hi Nikola, yes, this is troublesome! Indeed, you have to make a few moves until it is possible to remove the display. Unfortunately, there is no easier way.
Adriana Zwink - Yanıt Paylaş
Yes!, I had the same problem, I spent all day trying different ways to get out like three pesky screws. :( Any tips from anybody? I scoured the internet for a few hours, tried a few different things already but any help would be much appreciated!
Matt Farel - Yanıt Paylaş
Why do guides only show you how to take apart screens and not how to apply a new one?
Tee Jay - Yanıt Paylaş
Hi @Tee Jay, to reassemble your OnePlus Nord and install the new screen, follow the steps in this guide in reverse order.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 174
Son 30 gün: 685
Her zaman: 87,374
