Ana içeriğe geç
OontZ Angle 3 Battery Replacement
Neye ihtiyacın var
  1. OontZ Angle 3 Battery Replacement, Back Case: adım 1, 3 resimden 1. OontZ Angle 3 Battery Replacement, Back Case: adım 1, 3 resimden 2. OontZ Angle 3 Battery Replacement, Back Case: adım 1, 3 resimden 3.
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. OontZ Angle 3 Battery Replacement: adım 2, 1 resimden 1.
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. OontZ Angle 3 Battery Replacement: adım 3, 2 resimden 1. OontZ Angle 3 Battery Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
    FixBot'a Sor
    Yorum Ekle
  4. OontZ Angle 3 Battery Replacement, Battery: adım 4, 3 resimden 1. OontZ Angle 3 Battery Replacement, Battery: adım 4, 3 resimden 2. OontZ Angle 3 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Begin by removing the bottom piece, revealing the inner compartment with the speaker cables and battery.
    • Remove two (2) 11.7mm Phillips #0 screws from each side of the speaker plate.
    • Remove speaker plate from the front of the battery.
    FixBot'a Sor
    Yorum Ekle
  5. OontZ Angle 3 Battery Replacement: adım 5, 3 resimden 1. OontZ Angle 3 Battery Replacement: adım 5, 3 resimden 2. OontZ Angle 3 Battery Replacement: adım 5, 3 resimden 3.
    • Locate the soldering points for the battery on the motherboard face of the speaker.
    • Use a soldering iron to carefully disconnect the battery from the motherboard.
    • Learn more about soldering here.
    • Remove the battery from the inside compartment for replacement.
    • Be careful when soldering the new battery into the correct position on the motherboard, as a bad connection can cause the battery to overheat or catch on fire.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Mason Hollander
1.604 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G6
4 Üyeler
27Kılavuz Yorumları
What is the kind of battery used? Thanks!
Rodrigo Lopez - Yanıt Paylaş
Hi Rodrigo, the Oontz Angle 3 uses a rechargeable 2200mAh lithium-ion battery. Happy Fixing!
Kelsea Weber - Yanıt Paylaş
can i upgrade it to 4300mah?
klien klaus - Yanıt Paylaş
the one that I have has a "circuit board" attached to the battery. Is this what controls the recharging? If so, where do you get the battery with these?
Rob - Yanıt Paylaş
Hi Rob,use soldering iron disconnect the circuit board which come with old battery you going to replace, and soldering iron the disconnected circuit board back onto your new battery. The so called circuit board is to protect the battery from over discharge or over charge. Hope this help.
benckbenck - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 26
Son 30 gün: 161
Her zaman: 30,205
