Ana içeriğe geç
PDP Rematch Advanced Vibration Motors Replacement
Neye ihtiyacın var
  1. PDP Rematch Advanced Vibration Motors Replacement, Vibration Motors: adım 1, 3 resimden 1. PDP Rematch Advanced Vibration Motors Replacement, Vibration Motors: adım 1, 3 resimden 2. PDP Rematch Advanced Vibration Motors Replacement, Vibration Motors: adım 1, 3 resimden 3.
    • Orient the controller so the back side is facing up.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Vibration Motors Replacement: adım 2, 3 resimden 1. PDP Rematch Advanced Vibration Motors Replacement: adım 2, 3 resimden 2. PDP Rematch Advanced Vibration Motors Replacement: adım 2, 3 resimden 3.
    • Make sure the front shell of the controller is facing your work surface to prevent the face buttons from falling out.
    • Pull apart the controller's front and back shell with moderate force.
  3. PDP Rematch Advanced Vibration Motors Replacement: adım 3, 2 resimden 1. PDP Rematch Advanced Vibration Motors Replacement: adım 3, 2 resimden 2.
    • Use a soldering iron to desolder the two wires connecting the vibration motor to the motherboard.
    • Repeat for the other vibration motor if necessary.
  4. PDP Rematch Advanced Vibration Motors Replacement: adım 4, 2 resimden 1. PDP Rematch Advanced Vibration Motors Replacement: adım 4, 2 resimden 2.
    • Grab the motor and pull away from the back shell to remove the vibration motor.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Dylan Newcomb
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 195
