Ana içeriğe geç
PS3 Dual Shock 3 Controler Charging Port Replacement
Attak
Attak ve 3 diğer katkıda bulunanlar
En son October 14, 2024 tarihinde güncellendi
1 - 2 saat
Zor
Topluluk-Katkılı Kılavuz
To complete this repair, the user must possess skills in soldering, and proper tools needed to perform the repair.
  1. PS3 Dual Shock 3 Controler Charging Port Replacement, Opening the Controller: adım 1, 1 resimden 1.
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. PS3 Dual Shock 3 Controler Charging Port Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. PS3 Dual Shock 3 Controler Charging Port Replacement, Freeing the Motherboard: adım 3, 1 resimden 1.
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. PS3 Dual Shock 3 Controler Charging Port Replacement, Preparing the Soldering Station: adım 4, 1 resimden 1.
    • Prepare your station for the de-soldering of the charging port.
  5. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: adım 5, 3 resimden 1. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: adım 5, 3 resimden 2. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  6. PS3 Dual Shock 3 Controler Charging Port Replacement, Securing New Charging Port: adım 6, 1 resimden 1.
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  7. PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: adım 7, 2 resimden 1. PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: adım 7, 2 resimden 2.
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
Sonuç
To reassemble your device, follow instructions 1-3 in reverse order.
16 farklı kişi bu kılavuzu tamamladı.
Attak
622 İtibar
1 Kılavuz yazıldı
5 Yorum
Shall DualShock3 require other than GND and VBUS for charging only
and does DS3 follow the standards of USB-miniB (eg: Data wires flipping).
Sony does have some fame to sacrifice standards over extra capability delivery.
JanLS - Yanıt
Would you guys happen to know, if my labeling is correct? I’m going to upgrade to USB-C.
https://imgur.com/a/RL68Yw5
Howling Beats - Yanıt
Thank you it's really useful, tips,
Alan - Yanıt
Thanks for this. But now there are four different USB charging ports, how to tell which one of them is suitable? kasynparts eg
kasynlife - Yanıt
please attak if you still using this platfrom i really need you to help me with a ps3 controller pins
Deyaa Alshapshiri - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 114
Son 30 gün: 363
Her zaman: 20,522
