Ana içeriğe geç
Palm Treo 755p Antenna Replacement
Mike Shaw
Mike Shaw ve 11 diğer katkıda bulunanlar
En son January 5, 2024 tarihinde güncellendi
15 dakika
Orta
Yanlış Araçlar
The Palm Treo 755p is a small smartphone that was released in 2007. Like most phones, both past and present, an antenna is needed to capture and send out the radio signals that are used to communicate between devices. To make sure your Treo 755p will last as long as possible, you may need to replace the antenna. This guide will take you through the steps to safely remove the old antenna and install a new one to improve the life span of your device.
Warning: To ensure your safety, check that the phone battery is in good condition before attempting to use or repair the device. For more information on swollen batteries and how to handle them, please visit here: What to do With a Swollen Battery.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Palm Treo 755p Antenna Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 755p Antenna Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 755p Antenna Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Antenna Replacement: adım 2, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 2, 2 resimden 2.
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Antenna Replacement, Back Cover: adım 3, 2 resimden 1. Palm Treo 755p Antenna Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Antenna Replacement: adım 4, 1 resimden 1.
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Antenna Replacement: adım 5, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Antenna Replacement: adım 6, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 6, 2 resimden 2.
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Antenna Replacement: adım 7, 3 resimden 1. Palm Treo 755p Antenna Replacement: adım 7, 3 resimden 2. Palm Treo 755p Antenna Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  8. Palm Treo 755p Antenna Replacement, Antenna: adım 8, 1 resimden 1.
    • The antenna is on the back half of the phone.
  9. Palm Treo 755p Antenna Replacement: adım 9, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 9, 2 resimden 2.
    • Press in the four black clips using a spudger to pop off the upper-back cover.
  10. Palm Treo 755p Antenna Replacement: adım 10, 1 resimden 1.
    • Lift off the top of the back cover from the phone frame.
  11. Palm Treo 755p Antenna Replacement: adım 11, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 11, 2 resimden 2.
    • Gently pop off the antenna by pulling it away from the back cover.
Sonuç
Mike Shaw
601 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-6, Forte Winter 2011 Cal Poly, Team 14-6, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G6
6 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,767
