Ana içeriğe geç
Parrot Skycontroller 2 Buttons Replacement
Neye ihtiyacın var
    1. Parrot Skycontroller 2 Buttons Replacement, Battery: adım 1, 3 resimden 1. Parrot Skycontroller 2 Buttons Replacement, Battery: adım 1, 3 resimden 2. Parrot Skycontroller 2 Buttons Replacement, Battery: adım 1, 3 resimden 3.
      • Flip your controller face down.
      FixBot'a Sor
      Yorum Ekle
    2. Parrot Skycontroller 2 Buttons Replacement: adım 2, 1 resimden 1.
      • Remove one 9mm screw using a #4 flathead screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Parrot Skycontroller 2 Buttons Replacement: adım 3, 3 resimden 1. Parrot Skycontroller 2 Buttons Replacement: adım 3, 3 resimden 2. Parrot Skycontroller 2 Buttons Replacement: adım 3, 3 resimden 3.
      • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
      • Remove the cover by pulling up and out.
      FixBot'a Sor
      Yorum Ekle
    4. Parrot Skycontroller 2 Buttons Replacement: adım 4, 3 resimden 1. Parrot Skycontroller 2 Buttons Replacement: adım 4, 3 resimden 2. Parrot Skycontroller 2 Buttons Replacement: adım 4, 3 resimden 3.
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
      FixBot'a Sor
      Yorum Ekle
    5. Parrot Skycontroller 2 Buttons Replacement: adım 5, 2 resimden 1. Parrot Skycontroller 2 Buttons Replacement: adım 5, 2 resimden 2.
      • Remove the battery from its brackets by pulling up on the ends of the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Parrot Skycontroller 2 Buttons Replacement, Buttons: adım 6, 1 resimden 1.
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Parrot Skycontroller 2 Buttons Replacement: adım 7, 3 resimden 1. Parrot Skycontroller 2 Buttons Replacement: adım 7, 3 resimden 2. Parrot Skycontroller 2 Buttons Replacement: adım 7, 3 resimden 3.
      • Remove the seven silver 4mm screws from around the edge of the top plate using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      FixBot'a Sor
      Yorum Ekle
    3. Parrot Skycontroller 2 Buttons Replacement: adım 8, 1 resimden 1.
      • Remove the battery compartment plate by pulling up and out.
      FixBot'a Sor
      Yorum Ekle
    4. Parrot Skycontroller 2 Buttons Replacement: adım 9, 1 resimden 1.
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      FixBot'a Sor
      Yorum Ekle
    5. Parrot Skycontroller 2 Buttons Replacement: adım 10, 2 resimden 1. Parrot Skycontroller 2 Buttons Replacement: adım 10, 2 resimden 2.
      • Remove the face plate by pulling up and out.
      • Buttons will fall out when this plate is removed.
      FixBot'a Sor
      Yorum Ekle
    6. Parrot Skycontroller 2 Buttons Replacement: adım 11, 3 resimden 1. Parrot Skycontroller 2 Buttons Replacement: adım 11, 3 resimden 2. Parrot Skycontroller 2 Buttons Replacement: adım 11, 3 resimden 3.
      • Use some force pull up and out on the rubber backing for the buttons.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 653
