Ana içeriğe geç
Parrot Skycontroller 2 USB Port Replacement
Neye ihtiyacın var
  1. Parrot Skycontroller 2 USB Port Replacement, Battery: adım 1, 3 resimden 1. Parrot Skycontroller 2 USB Port Replacement, Battery: adım 1, 3 resimden 2. Parrot Skycontroller 2 USB Port Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your controller face down.
    FixBot'a Sor
    Yorum Ekle
  2. Parrot Skycontroller 2 USB Port Replacement: adım 2, 1 resimden 1.
    • Remove one 9mm screw using a #4 flathead screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Parrot Skycontroller 2 USB Port Replacement: adım 3, 3 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 3, 3 resimden 2. Parrot Skycontroller 2 USB Port Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    FixBot'a Sor
    Yorum Ekle
  4. Parrot Skycontroller 2 USB Port Replacement: adım 4, 3 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 4, 3 resimden 2. Parrot Skycontroller 2 USB Port Replacement: adım 4, 3 resimden 3.
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    FixBot'a Sor
    Yorum Ekle
  5. Parrot Skycontroller 2 USB Port Replacement: adım 5, 2 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 5, 2 resimden 2.
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. Parrot Skycontroller 2 USB Port Replacement, USB Port: adım 6, 1 resimden 1.
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • Pull back the sticker with your finger nail and remove one 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  7. Parrot Skycontroller 2 USB Port Replacement: adım 7, 3 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 7, 3 resimden 2. Parrot Skycontroller 2 USB Port Replacement: adım 7, 3 resimden 3.
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
    FixBot'a Sor
    Yorum Ekle
  8. Parrot Skycontroller 2 USB Port Replacement: adım 8, 1 resimden 1.
    • Remove the battery compartment plate by pulling up and out.
    FixBot'a Sor
    Yorum Ekle
  9. Parrot Skycontroller 2 USB Port Replacement: adım 9, 2 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 9, 2 resimden 2.
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
    FixBot'a Sor
    Yorum Ekle
  10. Parrot Skycontroller 2 USB Port Replacement: adım 10, 2 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 10, 2 resimden 2.
    • Remove the face plate by pulling up and out.
    FixBot'a Sor
    Yorum Ekle
  11. Parrot Skycontroller 2 USB Port Replacement: adım 11, 3 resimden 1. Parrot Skycontroller 2 USB Port Replacement: adım 11, 3 resimden 2. Parrot Skycontroller 2 USB Port Replacement: adım 11, 3 resimden 3.
    • Position the device so that the top panel is flat down on the table. You should have access to the USB Port.
    • Desolder the two connection points in the back of the USB port.
    • Desolder the four wires in the back of the USB port.
    • Remove the the component from the board.
    • Excessive heat can damage the port, so do not apply the soldering iron to the component for too long.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 1,182
