Ana içeriğe geç
Petcube Play 2 Camera Replacement
Neye ihtiyacın var
    1. Petcube Play 2 Camera Replacement, Motherboard: adım 1, 3 resimden 1. Petcube Play 2 Camera Replacement, Motherboard: adım 1, 3 resimden 2. Petcube Play 2 Camera Replacement, Motherboard: adım 1, 3 resimden 3.
      • Flip over the Petcube so the rubber bottom faces you.
      • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
      FixBot'a Sor
      Yorum Ekle
    2. Petcube Play 2 Camera Replacement: adım 2, 2 resimden 1. Petcube Play 2 Camera Replacement: adım 2, 2 resimden 2.
      • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
      • The glue may cause slight resistance, but the screws should come out with minimal effort.
      FixBot'a Sor
      Yorum Ekle
    3. Petcube Play 2 Camera Replacement: adım 3, 2 resimden 1. Petcube Play 2 Camera Replacement: adım 3, 2 resimden 2.
      • Carefully pry off the glass front panel using an opening pick or a spudger.
      • Do not force the front panel off, as it may crack and break.
      FixBot'a Sor
      Yorum Ekle
    4. Petcube Play 2 Camera Replacement: adım 4, 3 resimden 1. Petcube Play 2 Camera Replacement: adım 4, 3 resimden 2. Petcube Play 2 Camera Replacement: adım 4, 3 resimden 3.
      • Slide off the two covers, starting with the top plastic cover.
      • Slide out the internal assembly from the aluminum casing.
      FixBot'a Sor
      Yorum Ekle
    5. Petcube Play 2 Camera Replacement: adım 5, 3 resimden 1. Petcube Play 2 Camera Replacement: adım 5, 3 resimden 2. Petcube Play 2 Camera Replacement: adım 5, 3 resimden 3.
      • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
      • Remove the screw with a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Petcube Play 2 Camera Replacement: adım 6, 3 resimden 1. Petcube Play 2 Camera Replacement: adım 6, 3 resimden 2. Petcube Play 2 Camera Replacement: adım 6, 3 resimden 3.
      • Flip the cube onto its side to locate the pull tabs.
      • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
      FixBot'a Sor
      Yorum Ekle
    7. Petcube Play 2 Camera Replacement: adım 7, 3 resimden 1. Petcube Play 2 Camera Replacement: adım 7, 3 resimden 2. Petcube Play 2 Camera Replacement: adım 7, 3 resimden 3.
      • Gently disconnect the cable connectors to separate the two halves of the device.
      • Avoid pulling on the wires to prevent damage to the connectors.
      FixBot'a Sor
      Yorum Ekle
    8. Petcube Play 2 Camera Replacement: adım 8, 3 resimden 1. Petcube Play 2 Camera Replacement: adım 8, 3 resimden 2. Petcube Play 2 Camera Replacement: adım 8, 3 resimden 3.
      • Use a Phillips #1 screwdriver to remove the two 1mm screws.
      • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
      • Be gentle with the tabs. They will break under too much pressure.
      FixBot'a Sor
      Yorum Ekle
    1. Petcube Play 2 Camera Replacement, Camera: adım 9, 2 resimden 1. Petcube Play 2 Camera Replacement, Camera: adım 9, 2 resimden 2.
      • Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      • You can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
      • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated.
      FixBot'a Sor
      Yorum Ekle
    2. Petcube Play 2 Camera Replacement: adım 10, 3 resimden 1. Petcube Play 2 Camera Replacement: adım 10, 3 resimden 2. Petcube Play 2 Camera Replacement: adım 10, 3 resimden 3.
      • Use the Phillips #00 screwdriver to remove the three 1 mm screws securing the camera to the motherboard.
      • Remove the camera from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
JoshBerm
135 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Konn Spring 2024 UMass Dartmouth, Team 1-5, Konn Spring 2024 üyesi
UMASSD-KONN-S24S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 492
