Giriş
If the laser toy of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a controllable laser toy usable from the Petcube app. Repeated use or a defective laser might lead to the laser malfunctioning or not turning on.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection related issues and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Neye ihtiyacın var
Flip over the Petcube so the rubber bottom faces you.
Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
Use a Phillips #1 screwdriver to remove the seven screws from the part of the cube where the motherboard was removed.
Remove the plastic front to expose the board with the laser.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
