Ana içeriğe geç
Philips Norelco 5801XL Battery Replacement
Ben Gibbs
Ben Gibbs ve 4 diğer katkıda bulunanlar
En son July 15, 2024 tarihinde güncellendi
10 - 25 dakika
Orta
Eksik Adımlar
Use this guide to replace the rechargeable battery in the Philips Norelco 5801XL. The steps should be followed exactly as listed in the guide. Some soldering skills are required. Be sure to handle with care. For help with soldering: click here.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Philips Norelco 5801XL Battery Replacement, Battery: adım 1, 2 resimden 1. Philips Norelco 5801XL Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: adım 2, 2 resimden 1. Philips Norelco 5801XL Battery Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: adım 3, 3 resimden 1. Philips Norelco 5801XL Battery Replacement: adım 3, 3 resimden 2. Philips Norelco 5801XL Battery Replacement: adım 3, 3 resimden 3.
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: adım 4, 1 resimden 1.
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: adım 5, 1 resimden 1.
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: adım 6, 1 resimden 1.
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: adım 7, 3 resimden 1. Philips Norelco 5801XL Battery Replacement: adım 7, 3 resimden 2. Philips Norelco 5801XL Battery Replacement: adım 7, 3 resimden 3.
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ben Gibbs
361 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S3G2
4 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Yanıt
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 4,382
